sundevil67 30 Posted September 5, 2020 Posted September 5, 2020 I just learned about this device & was wondering what the general consensus was for how well this thing works with Emby & an Amazon/Fire Stick (Emby Server is running on Mac OS). My current solution that includes a wireless keyboard & a cheap remote that works with Mac OS is pretty kludgy, so something like this, if it's fairly easy to set up, sounds like a great option if it works. Thanks in advance!
WilhelmStroker 107 Posted September 5, 2020 Posted September 5, 2020 I love my Harmony. I have the one with the hub and it's very easy to set up. On the fire stick you can set up an automation that automatically starts emby when you start your activity.
Sammy 791 Posted September 5, 2020 Posted September 5, 2020 I use Elite with Hub and 900's on several TV's with several different setups using MiBox s and ShieldTV devices. I've use Harmony remotes for years now. Programming is a bit funky in that even advanced users must step through the wizard every time they want to make changes. Otherwise they're great.
