scagle21 0 Posted September 3, 2020 Posted September 3, 2020 I've got Lidarr connected to both emby and plex to notify apps on rename. Working for plex, not working for emby. If any file gets renamed, emby can no longer play it. I've tried rescanning the library, still doesn't update it. Right now I'm trying deleted the entire library and reading it, still scanning so yet to see if it works. even if it does though, as lidarr renames and replaces files with higher quality ones Ill continue to have the same problem. I've noticed these error messages in the log though, and it think it may be the root problem....any suggestions? 2020-09-03 06:28:26.003 Info HttpClient: HttpClientManager GET: https://musicbrainz.emby.tv/ws/2/artist/?query="James+Cotton"&dismax=true 2020-09-03 06:28:26.138 Error HttpClient: Error TrustFailure getting response from *** Error Report *** Version: 4.4.3.0 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 6.8.0.105 (tarball Fri Apr 10 09:44:13 UTC 2020) Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/mono/6.8.0.105/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.4.3.0 System.Net.WebException: System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) ---> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. ---> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <b373cc92cfb94ef6a19b4f1140645494>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <b373cc92cfb94ef6a19b4f1140645494>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <b373cc92cfb94ef6a19b4f1140645494>:0 --- End of inner exception stack trace --- at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebOperation.Run () [0x0009a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00020] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <9d3f0d4bd0fb4c1e8b6c2ac1ba1303ac>:0 Source: System TargetSite: System.Net.WebResponse EndGetResponse(System.IAsyncResult) InnerException: System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. Source: mscorlib TargetSite: Void Throw() at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <b373cc92cfb94ef6a19b4f1140645494>:0 InnerException: Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 Source: System TargetSite: Boolean ProcessHandshake() at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <b373cc92cfb94ef6a19b4f1140645494>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <b373cc92cfb94ef6a19b4f1140645494>:0 2020-09-03 06:28:26.149 Error App: Error in MusicBrainz *** Error Report *** Version: 4.4.3.0 Command line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 Operating system: Unix 4.4.59.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 6.8.0.105 (tarball Fri Apr 10 09:44:13 UTC 2020) Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/mono/6.8.0.105/lib/mono/4.5/mscorlib.dll System.Environment.Version: 4.0.30319.42000 Processor count: 4 Program data path: /var/packages/EmbyServer/target/var Application directory: /volume1/@appstore/EmbyServer/releases/4.4.3.0 MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Error: TrustFailure (Authentication failed, see inner exception.) ---> System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) ---> System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. ---> Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <b373cc92cfb94ef6a19b4f1140645494>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <b373cc92cfb94ef6a19b4f1140645494>:0 --- End of inner exception stack trace --- at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <b373cc92cfb94ef6a19b4f1140645494>:0 --- End of inner exception stack trace --- at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebOperation.Run () [0x0009a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00020] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <9d3f0d4bd0fb4c1e8b6c2ac1ba1303ac>:0 --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsyncInternal (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x00858] in <4b2b35e458474e708c04b3533f59ad82>:0 at Emby.Server.Implementations.HttpClientManager.HttpClientManager.SendAsync (MediaBrowser.Common.Net.HttpRequestOptions options, System.String httpMethod) [0x0009e] in <4b2b35e458474e708c04b3533f59ad82>:0 at MusicBrainz.MusicBrainzAlbumProvider.GetMusicBrainzResponse (System.String url, System.Boolean isSearch, System.Boolean forceMusicBrainzProper, System.Threading.CancellationToken cancellationToken) [0x001da] in <cb7b18b46507442fa2bbce5337715457>:0 at MusicBrainz.MusicBrainzArtistProvider.GetSearchResults (MediaBrowser.Controller.Providers.ArtistInfo searchInfo, System.Threading.CancellationToken cancellationToken) [0x0022e] in <cb7b18b46507442fa2bbce5337715457>:0 at MusicBrainz.MusicBrainzArtistProvider.GetMetadata (MediaBrowser.Controller.Providers.ArtistInfo id, System.Threading.CancellationToken cancellationToken) [0x00094] in <cb7b18b46507442fa2bbce5337715457>:0 at MediaBrowser.Providers.Manager.MetadataService`2[TItemType,TIdType].ExecuteRemoteProviders (MediaBrowser.Controller.Providers.MetadataResult`1[T] temp, System.String logName, TIdType id, System.Collections.Generic.IEnumerable`1[T] providers, System.Threading.CancellationToken cancellationToken) [0x00138] in <6ae0ccbd7ce14a2bb4884c56de031324>:0 Source: mscorlib TargetSite: Void Throw() InnerException: System.Net.WebException: Error: TrustFailure (Authentication failed, see inner exception.) Source: System TargetSite: System.Net.WebResponse EndGetResponse(System.IAsyncResult) at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x0021a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.InitConnection (System.Net.WebOperation operation, System.Threading.CancellationToken cancellationToken) [0x00141] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebOperation.Run () [0x0009a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebCompletionSource`1[T].WaitForCompletion () [0x00094] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.HttpWebRequest.RunWithTimeoutWorker[T] (System.Threading.Tasks.Task`1[TResult] workerTask, System.Int32 timeout, System.Action abort, System.Func`1[TResult] aborted, System.Threading.CancellationTokenSource cts) [0x000f8] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.HttpWebRequest.EndGetResponse (System.IAsyncResult asyncResult) [0x00020] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x0000f] in <9d3f0d4bd0fb4c1e8b6c2ac1ba1303ac>:0 InnerException: System.Security.Authentication.AuthenticationException: Authentication failed, see inner exception. Source: mscorlib TargetSite: Void Throw() at Mono.Net.Security.MobileAuthenticatedStream.ProcessAuthentication (System.Boolean runSynchronously, Mono.Net.Security.MonoSslAuthenticationOptions options, System.Threading.CancellationToken cancellationToken) [0x00262] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MonoTlsStream.CreateStream (System.Net.WebConnectionTunnel tunnel, System.Threading.CancellationToken cancellationToken) [0x0016a] in <b373cc92cfb94ef6a19b4f1140645494>:0 at System.Net.WebConnection.CreateStream (System.Net.WebOperation operation, System.Boolean reused, System.Threading.CancellationToken cancellationToken) [0x001ba] in <b373cc92cfb94ef6a19b4f1140645494>:0 InnerException: Mono.Btls.MonoBtlsException: Ssl error:1000007d:SSL routines:OPENSSL_internal:CERTIFICATE_VERIFY_FAILED at /source/mono/external/boringssl/ssl/handshake_client.c:1132 Source: System TargetSite: Boolean ProcessHandshake() at Mono.Btls.MonoBtlsContext.ProcessHandshake () [0x00048] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake (Mono.Net.Security.AsyncOperationStatus status, System.Boolean renegotiate) [0x000da] in <b373cc92cfb94ef6a19b4f1140645494>:0 at (wrapper remoting-invoke-with-check) Mono.Net.Security.MobileAuthenticatedStream.ProcessHandshake(Mono.Net.Security.AsyncOperationStatus,bool) at Mono.Net.Security.AsyncHandshakeRequest.Run (Mono.Net.Security.AsyncOperationStatus status) [0x00006] in <b373cc92cfb94ef6a19b4f1140645494>:0 at Mono.Net.Security.AsyncProtocolRequest.ProcessOperation (System.Threading.CancellationToken cancellationToken) [0x000fc] in <b373cc92cfb94ef6a19b4f1140645494>:0
Happy2Play 9811 Posted September 3, 2020 Posted September 3, 2020 Since you are getting a trustfailure have a look here. Pretty sure they are all related as there are several topics pointing to the beta for a fix.
scagle21 0 Posted September 3, 2020 Author Posted September 3, 2020 Cheers! trying reinstall of plugin now
