KingKoopa08 17 Posted September 1, 2020 Posted September 1, 2020 Hey I am trying to figure out why emby is throwing a 404 error when watching a channel only on certain streams. Anyone have an idea? I have attached the logs. embyserver(1).txt ffmpeg-transcode-09baac70-e9dc-486c-9f9a-a019b511ac37_1.txt
Carlo 4561 Posted September 1, 2020 Posted September 1, 2020 Hi, That server log file stops time wise before the ffmpeg log by about 6 minutes. So no way to compare the two.
KingKoopa08 17 Posted September 1, 2020 Author Posted September 1, 2020 Aww crap. My bad. One sec I will reproduce and get new files.
KingKoopa08 17 Posted September 1, 2020 Author Posted September 1, 2020 2 minutes ago, cayars said: Sounds good. This one did play direct instead of transcoding. So I don't have the transcode file (I am assuming thats why I didn't get an updated one). I attached the new server file. embyserver(2).txt
KingKoopa08 17 Posted September 1, 2020 Author Posted September 1, 2020 This is what I see I am concerned is causing the stream to drop. 2020-09-01 13:31:33.202 Info HttpServer: HTTP Response 404 to 127.0.0.1. Time: 2ms. http://127.0.0.1:8096/LiveTv/LiveStreamFiles/d9c7df74a0ca493a92139be8459314fc/stream.ts 2020-09-01 13:31:33.203 Info VideoHlsService: AppendExtraLogData - Read graph file: /var/lib/emby/logs/ffmpeg-transcode-09baac70-e9dc-486c-9f9a-a019b511ac37_1graph.txt 2020-09-01 13:31:33.204 Info VideoHlsService: AppendExtraLogData - Deserialized GraphData fileStream: {0:n} bytes Graph Count: 0 2020-09-01 13:31:33.204 Info VideoHlsService: AppendExtraLogData - File Deleted 2020-09-01 13:31:33.204 Info VideoHlsService: ProcessRun 'StreamTranscode 09baac' Process exited with code 1 2020-09-01 13:31:33.250 Error HttpServer: Error processing request *** Error Report *** Version: 4.4.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.112 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 20 Program data path: /var/lib/emby Application directory: /opt/emby-server/system System.Exception: System.Exception: Error starting ffmpeg at Emby.Server.MediaEncoding.Api.BaseStreamingService.StartFfMpeg(StreamState state, String outputPath, CancellationTokenSource cancellationTokenSource, Boolean acquireResources) at Emby.Server.MediaEncoding.Api.Hls.BaseHlsService.ProcessRequest(StreamRequest request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.MediaEncoding TargetSite: Void MoveNext()
Carlo 4561 Posted September 1, 2020 Posted September 1, 2020 I popped in with Teamviewer while having dinner to see this and we tried the stream in VLC as well. It starts/stops, pauses, etc. Seems like it's a subpar stream from the provider. Happens with IPTV. But there was nothing wrong with the Emby setup and everything seems to be configured well! This is just going to be one of those things out of our control to do anything about.
KingKoopa08 17 Posted September 1, 2020 Author Posted September 1, 2020 9 minutes ago, cayars said: I popped in with Teamviewer while having dinner to see this and we tried the stream in VLC as well. It starts/stops, pauses, etc. Seems like it's a subpar stream from the provider. Happens with IPTV. But there was nothing wrong with the Emby setup and everything seems to be configured well! This is just going to be one of those things out of our control to do anything about. @cayars you rock! Thank you for your help! 1
