MichelVEU 0 Posted September 7, 2020 Posted September 7, 2020 22 hours ago, cayars said: But Happy2Play has already mentioned the likely outcome of what you need to do above to fix the trust/SSLl issues. Yes, manually installed (upgraded from stable) the beta from https://github.com/MediaBrowser/Emby.Releases/releases/tag/4.5.0.23 on my 916+ and that solved the certificate error. Thanks!
Carlo 4561 Posted September 7, 2020 Posted September 7, 2020 3 hours ago, juro1971 said: Whom do you recommend to send the logs? Luke? If you could send it to both Luke and I (list us both in the PM) that would be great. Add a link back to this thread so we know what the log is in reference to. Thanks
juro1971 11 Posted September 7, 2020 Author Posted September 7, 2020 5 minutes ago, cayars said: If you could send it to both Luke and I (list us both in the PM) that would be great. Add a link back to this thread so we know what the log is in reference to. Thanks done
juro1971 11 Posted September 10, 2020 Author Posted September 10, 2020 Hi All, any update on this? Can I solve this by my own (e.g. with a change in a configuration?!) or is this a bug with has to be solved by the developpers? Thanks! Jürgen
juro1971 11 Posted September 10, 2020 Author Posted September 10, 2020 no! In the meantime I updated tp the lates beta. No change. Still no artist informationen.
Luke 42239 Posted September 10, 2020 Posted September 10, 2020 1 hour ago, juro1971 said: no! In the meantime I updated tp the lates beta. No change. Still no artist informationen. What architecture is your NAS ?
juro1971 11 Posted September 11, 2020 Author Posted September 11, 2020 Hi Luke, I was womdering why you ask all these questions and what these have to do with the problem. All other emby scrapers work perfect (Movies, Series, Album, Cover). Scrapers of other tools such as Kodi work perfect. The only scraper which is not working is the emby music artist scraper! My router is a fritzbox 7580. Here an external drive is connceted via USB 3.0. All the media files a stored here. From the shield, where emby is installed, I created a file share connection (SMB) to the external media storage. In emby I so have conncetion to the media folders on the external storage. Before the shiled I used fire TV stick. Beside the upscalibg functionality I bought the Shield, because native SMB is supported (this is still not supported in emby, in Kodi it is). Now I can use emby as central media repository an all my other Kodi based media client are connected to the central emby data base. That was the plan! Hopefully the bug will be solved. Does noboby else have this problem?! Is this an accepted bug or not? Thans and best regards JuRo
Luke 42239 Posted September 12, 2020 Posted September 12, 2020 On 9/6/2020 at 7:12 AM, MichelVEU said: I hope that is not for me. You really want me to anonymize 65Mb of errors? @MichelVEU this topic is about the android server and your issue is on Synology, so that got me mixed up a bit. In your case, please see here:
Luke 42239 Posted September 12, 2020 Posted September 12, 2020 On 9/11/2020 at 2:53 AM, juro1971 said: Hi Luke, I was womdering why you ask all these questions and what these have to do with the problem. All other emby scrapers work perfect (Movies, Series, Album, Cover). Scrapers of other tools such as Kodi work perfect. The only scraper which is not working is the emby music artist scraper! My router is a fritzbox 7580. Here an external drive is connceted via USB 3.0. All the media files a stored here. From the shield, where emby is installed, I created a file share connection (SMB) to the external media storage. In emby I so have conncetion to the media folders on the external storage. Before the shiled I used fire TV stick. Beside the upscalibg functionality I bought the Shield, because native SMB is supported (this is still not supported in emby, in Kodi it is). Now I can use emby as central media repository an all my other Kodi based media client are connected to the central emby data base. That was the plan! Hopefully the bug will be solved. Does noboby else have this problem?! Is this an accepted bug or not? Thans and best regards JuRo I'm not yet sure what your issue is. We are looking into it.
Carlo 4561 Posted September 12, 2020 Posted September 12, 2020 (edited) On 9/11/2020 at 2:53 AM, juro1971 said: Beside the upscalibg functionality I bought the Shield, because native SMB is supported (this is still not supported in emby, in Kodi it is). Now I can use emby as central media repository an all my other Kodi based media client are connected to the central emby data base. That was the plan! Hopefully the bug will be solved. Hi, Why do you say SMB is not supported? Edited September 12, 2020 by cayars
juro1971 11 Posted September 14, 2020 Author Posted September 14, 2020 On 12/09/2020 at 18:33, cayars said: Hi, Why do you say SMB is not supported? Because native SMB is it is not supported by Emby !
Kykdkydkyfykd 0 Posted September 14, 2020 Posted September 14, 2020 I can confirm this issue is happening on my Nvidia Shield as well. Starting from an empty library metadata import only works for a small percentage of files in the library. See attached log. embyserver.txt
Carlo 4561 Posted September 14, 2020 Posted September 14, 2020 5 hours ago, juro1971 said: Because native SMB is it is not supported by Emby ! Again I'll ask what do you mean? Do you not use any mapped network drives? I use both SMS and NFS with Emby and Emby has no issues with either. This is handled at the OS level and not something Emby itself has to speak.
juro1971 11 Posted November 8, 2020 Author Posted November 8, 2020 Hi all, I started the post month ago. In the meantime I installed everthing new. All betas tested. The problem is still there. All other stuff and scrapers work fine for me. Is this now an accepted bug or not? Is a fix planned? Thanks! JuRo
juro1971 11 Posted November 8, 2020 Author Posted November 8, 2020 (edited) Hallo zusammen, ich starte mal hier noch eine Anfrage im deutschen Bereich. Ich habe hier vor Monaten mein Problem beschrieben. Getan hat sich seit dem leider gar nichts. Das Nvidia Shield TV ist über LAN an die Fritzbox angeschlossen. An der Fritzbox hängt am USB 3 Anschluss ne Festplatte mit den MedienFiles. Freigabe SMB3. Am Shiled TV ist das die Freigabe gemountet. Emby nutze ich ansatzweise auf Windows bereits über Jahre, meist ohne Probleme. Hier funktioniert auch das Artist Scraping im Bereich Musik. Mein Media Center PC habe ich abgeschafft und durch obiges setup ersetzt. Auf Android unter Shield TV läuft alles soweit ok bis eben auf das Musik Artist Scraping (vover und meta daten geht nicht egal welcher Scraper eingestellt ist) eben leider nicht. Album Cover geht. Primär nutze ich Kodi auf verschiedenen Devices. Ich möchte alle Kodi Clients mit der "zentralen Emby DB" verknüpfen. Scraping het generell auf Emby ja auch besser (wenn es funktioniert). Ein paar Leutre haben ähnliche Probleme. Ichhabe bisher kleine Lösung gefunden. Kann hier kjemand weiter helfen? Vielen Dank und Gruß JuRo Edited November 8, 2020 by juro1971
Luke 42239 Posted November 12, 2020 Posted November 12, 2020 @juro1971 I've merged your two topics together. Thanks.
