Emby Tower 34 Posted September 2, 2020 Author Posted September 2, 2020 So, there is already a fix in your internal source code tree, but until now it isn't available for beta releases?! Or will it be in the next beta?!
Happy2Play 9802 Posted September 2, 2020 Posted September 2, 2020 So are we saying scroll rows will be able to accomidate images of different aspectratio? So mixing say 4:3 and 16:9 images in the same row? I can see that being a cosmetic nightmare.
pwhodges 2028 Posted September 2, 2020 Posted September 2, 2020 (edited) I can see the logic for making the images evenly spaced, so there's the choice of fitting the 4:3 images into the same space as the 16:9 ones either by stretching them or pillarboxing them. Personally I find actual distortion of the image an unacceptable corruption. The number of 4:3 films will usually be far smaller, so appeals to some supposed "ugliness" of using pillarboxing do not impress me. In the case of series, though, a change of aspect ratio is very unlikely, so spacing according to the actual image aspect ratio makes complete sense. On checking, I have exactly two series whose aspect ratio changes between seasons (one of which covers 35 years, so that's no surprise); but even then, it is simply a single switch from 4:3 to 16:9, which doesn't strike me as a cosmetic nightmare, really. Paul Edited September 2, 2020 by pwhodges
Luke 42210 Posted September 4, 2020 Posted September 4, 2020 @pwhodges I've merged your topic into here as it is discussing the same issue. Thanks.
Emby Tower 34 Posted September 23, 2020 Author Posted September 23, 2020 I've installed Server 4.5, but the problem still exists ...
Luke 42210 Posted September 23, 2020 Posted September 23, 2020 We're looking into it. Thanks for reporting.
softworkz 5129 Posted September 23, 2020 Posted September 23, 2020 3 hours ago, Emby Tower said: I've installed Server 4.5, but the problem still exists ... Did you refresh metadata (including images)? Are we talking about videos that are showing "Anamorphic=yes" ?
softworkz 5129 Posted September 23, 2020 Posted September 23, 2020 @pwhodges - is it fixed in your case? (I'm asking because I had tested the fix against sample videos he had provided)
pwhodges 2028 Posted September 23, 2020 Posted September 23, 2020 Where do I find the chapter images to delete the wrong ones so I can check? Paul
