Pommes 12 Posted August 28, 2020 Posted August 28, 2020 (edited) Hi I have one library for my downloaded youtube videos with several folders (for every youtube channel one) Because they are youtube videos there is no metadata from moviedb or other and one frame is taken as prev. Very warped with the default view. Because of that i went to setting and choose the view "thumb" image 1 But this is not used for the subfolders for each channel and i dont want to go through 100ths of folders and set it in every folder manually. Can i set this as default for the whole library. The second thing is do i need to click sth that the prev images are rendert? because some of the videos do have prevs but others not and it isnt rendering at the moment. Thanks Edited August 28, 2020 by Pommes
Happy2Play 9802 Posted August 28, 2020 Posted August 28, 2020 There currently is no option to change all levels of folder view, only the level being viewed.
