tge101 0 Posted August 28, 2020 Posted August 28, 2020 I just purchased Premiere specifically to try out the Live TV section. I'm able to find my HDHomerun DUO, no problem. I picked the Emby Guide Data source and local OTA. But, when i go to Refresh Guide Data, the gray pops up for a few seconds and goes away. No channel data is downloaded or really anything at all. I'm stuck.
Carlo 4560 Posted August 28, 2020 Posted August 28, 2020 Hi, Did you map your channels? Here's a knowledge base article showing the process. https://support.emby.media/support/solutions/articles/44001848809-live-tv-channel-mapping
tge101 0 Posted August 28, 2020 Author Posted August 28, 2020 I tried that, but nothing shows up. It's not pulling anything at all.
Carlo 4560 Posted August 28, 2020 Posted August 28, 2020 That makes it look like you either have no tuner installed or you setup the guide and didn't select all tuners or at least the tuner you previously setup.
Carlo 4560 Posted August 28, 2020 Posted August 28, 2020 Here is a knowledge base article that walks you through the whole setup process. https://support.emby.media/support/solutions/articles/44001160415-live-tv-setup
Solution tge101 0 Posted August 28, 2020 Author Solution Posted August 28, 2020 (edited) edit - for whatever reason, it kept detecting it as the wrong IP (but successfully?). i manually added the correct ip and it's working. Edited August 28, 2020 by tge101
Carlo 4560 Posted August 28, 2020 Posted August 28, 2020 Click on the Emby Guide Data above in that picture and show us what that page looks like please.
Carlo 4560 Posted August 28, 2020 Posted August 28, 2020 Please do a screen capture of what you see when you open this link. http://192.168.86.133/lineup.html
