fabiojrsantos 1 Posted August 28, 2020 Posted August 28, 2020 I work Emby Server very well in RPi 3 Model B. My question is... what is the maximum resolution it supports? In my scenario of course. I can watch movies in 1080p easily.
Luke 42238 Posted August 28, 2020 Posted August 28, 2020 Hi, there is no resolution limit. It depends on the device you're playing from, and what the maximum resolution is that it supports. What device are you playing on?
fabiojrsantos 1 Posted August 29, 2020 Author Posted August 29, 2020 (edited) 14 hours ago, Luke said: Hi, there is no resolution limit. It depends on the device you're playing from, and what the maximum resolution is that it supports. What device are you playing on? Thanks for your answer architect. It's a TV LG 4K. But I think my server looks good only at 1080p so as not to stress RPi too much, if it doesn't explode. Edited August 29, 2020 by fabiojrsantos The question was about the reading device.
Luke 42238 Posted August 30, 2020 Posted August 30, 2020 The RPI may have trouble transcoding, but the LG app can still direct play 4K content without server transcoding (in some cases).
