Luke 42246 Posted September 5, 2020 Posted September 5, 2020 Just now, b0mb said: I think I can't send a log from the mobile app on the Android TV because of Navigation I provided a link with instructions.
b0mb 36 Posted September 5, 2020 Author Posted September 5, 2020 i´ll try to catch the log later but i guess it won´t be easy... i´ve allready checked that data folder using fx explorer in the morning and i don´t know where i can find the sideloaded mobile app on that stick ...
b0mb 36 Posted September 5, 2020 Author Posted September 5, 2020 so did another try but it seems like i don´t have access to the data folder on the android tv device i´ve managed to sideload and configure a wol app that i use on my mobile phone https://play.google.com/store/apps/details?id=de.ralischer.wakeonlan this one works ...
Luke 42246 Posted September 5, 2020 Posted September 5, 2020 6 hours ago, b0mb said: so did another try but it seems like i don´t have access to the data folder on the android tv device i´ve managed to sideload and configure a wol app that i use on my mobile phone https://play.google.com/store/apps/details?id=de.ralischer.wakeonlan this one works ... What info did you configure into the app to send a WOL command? In our case it's all automatic, which works for most people, but if you have some non-default criteria that needs to be configured on the wake signal, then currently we don't offer a way for you to configure that.
b0mb 36 Posted September 5, 2020 Author Posted September 5, 2020 I configure the ip and Mac address... That's how I do it with all my devices
