b0mb 36 Posted August 28, 2020 Posted August 28, 2020 Hi! I´ve installed the Emby App on a MI TV Stick connected via Wifi to my local LAN. The App is working fine so far but WOL doesn´t work. When the server is in standby and i start the app i get the window where i can choose WAKE but it doesn´t. Any conclusion for this? Thx in advance! b0mb PS.: WOL on Server is usually working fine. Emby on Androd TV is the latest build and on m unraid server latest official docker container is running.
b0mb 36 Posted August 28, 2020 Author Posted August 28, 2020 11 minutes ago, ebr said: Hi. Do you have different sub-nets? nope
ebr 16338 Posted August 28, 2020 Posted August 28, 2020 Proxy or anything else interesting in the network? Does the server dashboard show the proper LAN address?
b0mb 36 Posted August 28, 2020 Author Posted August 28, 2020 nothing special, i´m directly connecting to the ip and the server does show the correct LAN adress
ebr 16338 Posted August 28, 2020 Posted August 28, 2020 Can you attempt to wake the server and then send a log from the app?
b0mb 36 Posted August 28, 2020 Author Posted August 28, 2020 i hope that worked well... when i pressed the button to send you the report out of the app the system rebooted...
ebr 16338 Posted August 29, 2020 Posted August 29, 2020 8 hours ago, b0mb said: i hope that worked well... when i pressed the button to send you the report out of the app the system rebooted... Never heard of that before. Can you please try again. Also, please include the other information requested. Thanks. Quote Then add the following information to your report in the forum: Exactly what you were doing and what happened. Include the name of whatever you played if it is a playback problem The time you sent the log (in Eastern Time please - UTC -5) The name of the Emby user on the local server that was logged in at the time
b0mb 36 Posted August 29, 2020 Author Posted August 29, 2020 (edited) I've send the report now successfully. User is Motti. i´ve started the app and tried to connect to the server that was sleeping. i´ve chosen the WAKE option but nothing happened at all. then i´ve turned to server on using wol app on my mobile phone and connected to the server using the android tv app which was successfully. after that i´ve chosen the user and the send report option. Btw using the Android app on my mobile phone everything is working fine. Edited August 29, 2020 by b0mb
ebr 16338 Posted August 29, 2020 Posted August 29, 2020 Thanks, but unfortunately, the log doesn't contain the attempt to wake. I'll see if I can test this out to reproduce.
b0mb 36 Posted August 29, 2020 Author Posted August 29, 2020 (edited) 17 hours ago, ebr said: Thanks, but unfortunately, the log doesn't contain the attempt to wake. I'll see if I can test this out to reproduce. i think this is where the problem is... when i press wake nothing happens if i press wake on the android app on my phone there comes another screen up with a spinner and the msg that emby is trying to wake the server Edited August 30, 2020 by b0mb
b0mb 36 Posted August 30, 2020 Author Posted August 30, 2020 I´ve tried now the emby app on my tv which has android tv system and it´s the same like on the mi tv stick... so i think it´s a problem of the app ^^
ebr 16338 Posted August 30, 2020 Posted August 30, 2020 We're still investigating but I'm wondering if it is related to Android or the device because, so far, it appears both apps are sending identical information.
b0mb 36 Posted August 31, 2020 Author Posted August 31, 2020 6 hours ago, ebr said: We're still investigating but I'm wondering if it is related to Android or the device because, so far, it appears both apps are sending identical information. only thing i can say is two devices same app same problem
ebr 16338 Posted August 31, 2020 Posted August 31, 2020 6 hours ago, b0mb said: only thing i can say is two devices same app same problem Right, I mean the fact that these are TV devices running the Android TV OS.
Luke 42246 Posted September 2, 2020 Posted September 2, 2020 As a test, can you try side-loading the mobile app on the same device and see if it works with that?
ebr 16338 Posted September 2, 2020 Posted September 2, 2020 45 minutes ago, Luke said: As a test, can you try side-loading the mobile app on the same device and see if it works with that? That's a great idea.
Luke 42246 Posted September 2, 2020 Posted September 2, 2020 11 minutes ago, b0mb said: I´ll try when i find some time That would be very helpful. thanks.
b0mb 36 Posted September 5, 2020 Author Posted September 5, 2020 i´ve sideloaded the emby android app now on the mi tv stick... was kinda tricky to navigate ^^ wol doesn´t work....
Luke 42246 Posted September 5, 2020 Posted September 5, 2020 2 hours ago, b0mb said: i´ve sideloaded the emby android app now on the mi tv stick... was kinda tricky to navigate ^^ wol doesn´t work.... Please provide a log from the app: Thanks.
b0mb 36 Posted September 5, 2020 Author Posted September 5, 2020 i´ve allready sent the report 1 or 2 weeks ago but @ebr said that nothing about WOL has been protocolled... i also think that when i choose WAKE nothing really happens....
Luke 42246 Posted September 5, 2020 Posted September 5, 2020 2 minutes ago, b0mb said: i´ve allready sent the report 1 or 2 weeks ago but @ebr said that nothing about WOL has been protocolled... i also think that when i choose WAKE nothing really happens.... A log from the mobile app is what i requested. You haven't supplied that yet.
b0mb 36 Posted September 5, 2020 Author Posted September 5, 2020 Ma log from the mobile app where it's working out from the Android TV? I think I can't send a log from the mobile app on the Android TV because of Navigation
