Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 TV Shows\Ultraman\Season 1\1. Ultra Operations No. 1 (July 17 1966)\1. Ultra Operations No. 1.mkv TV Shows\Ultraman\Season 1\2. Defeat the Invaders! (July 24, 1966)\2. Defeat the Invaders!.mkv
Happy2Play 9802 Posted August 28, 2020 Posted August 28, 2020 1 hour ago, Ronstang said: External IDs are IMDB, TheMovieDB, and TVDB right but what are they? If I use naming like this they display properly, files named the same as folders.
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 (edited) The only difference for mine is I don't have the original air dates in the actual file names. Plus....my Series icon only shows 37 episodes so it doesn't see my missing ones at all Edited August 28, 2020 by Ronstang
Happy2Play 9802 Posted August 28, 2020 Posted August 28, 2020 Are you External ids correct? I don't have a issue removing the original air date from file either.
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 I'm sorry but I simply don't know what you mean by my external IDs being correct
Happy2Play 9802 Posted August 28, 2020 Posted August 28, 2020 11 minutes ago, Ronstang said: I'm sorry but I simply don't know what you mean by my external IDs being correct What numbers are displayed in those external id fields?
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 For the individual episodes or the series as a whole?
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 Yes, my external IDs are exactly the same as those, but when I check the Season ID it only has one from TheTVDB which is 6000
Happy2Play 9802 Posted August 28, 2020 Posted August 28, 2020 9 minutes ago, Ronstang said: For the individual episodes or the series as a whole? These series as everything below it comes from that series metadata normally.
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 I answered you at the same time you answered me
Happy2Play 9802 Posted August 28, 2020 Posted August 28, 2020 1 minute ago, Ronstang said: Yes, my external IDs are exactly the same as those, but when I check the Season ID it only has one from TheTVDB which is 6000 I have the same for season 1. So without looking at everything in reference to Season 1 I am out of ideas as I can reproduce a issue with using -part in naming, but renaming resolves the issue for me.
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 Mine just don't show up at all no matter what I do
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 No matter what I do it shows I only have 37 episodes yet I have 39 in the folder
Carlo 4561 Posted August 28, 2020 Posted August 28, 2020 Have you tried moving these files out of the library, scanning then starting to put them back using the 2 that go missing first? I mean put those 2 in and scan library to see what happens? 1
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 2 minutes ago, cayars said: Have you tried moving these files out of the library, scanning then starting to put them back using the 2 that go missing first? I mean put those 2 in and scan library to see what happens? No, I''l try that. I only moved those two out, rescanned, moved them back in and then rescanned.....3 times
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 OK, I did that and for some reason episode 26 and 27 show up as episode 1 and 2
pwhodges 2028 Posted August 28, 2020 Posted August 28, 2020 (edited) Try renaming just those, using the s00e00 notation. Paul Edited August 28, 2020 by pwhodges
Carlo 4561 Posted August 28, 2020 Posted August 28, 2020 2 minutes ago, Ronstang said: OK, I did that and for some reason episode 26 and 27 show up as episode 1 and 2 That's what Happy2Play was saying earlier that you likely had multi-versions Can you show us the exact naming convention being used for these two files, folders, and parent folder name?
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 TV Shows\Ultraman\Season 1\26. Monster Majesty (1) (Jamuary 8, 1967)\26. Monster Majesty (1) .mkv TV Shows\Ultraman\Season 1\27. Monster Majesty (2) (Jamuary 15, 1967)\27. Monster Majesty (2) .mkv
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 I checked the indivdual files and they are different videos so the content of the files are correct, Emby is just indexing them incorrectly
Carlo 4561 Posted August 28, 2020 Posted August 28, 2020 I just tried the same as what you have above and it identified them correctly. I'm using the following two meta providers setup in my library in this order. TheTVDB, The MovieDB
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 OK, I also had the Open Move Database as number three and I simply unchecked that and refreshed the metadata and now everything is fine for some odd reason
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 Thanks all......but I'm not sure what was wrong
Carlo 4561 Posted August 28, 2020 Posted August 28, 2020 I do have a question for you. Where did you get your names from? For example this is the series you're talking about correct? https://www.imdb.com/title/tt0060038/?ref_=ttep_ep_tt
Ronstang 294 Posted August 28, 2020 Author Posted August 28, 2020 Yes sir, that is the correct series and I got my episode names in English from Amazon.....LOL
