PenkethBoy 2068 Posted September 17, 2020 Posted September 17, 2020 Thanks might have overdone the font size a tad
PenkethBoy 2068 Posted September 17, 2020 Posted September 17, 2020 @arrbee99 /* --- Hide Beta Message in Dashboard --- */ .betaInfoBanner {display: none} 1
Alexwerilles 3 Posted September 27, 2020 Author Posted September 27, 2020 On 9/14/2020 at 2:31 PM, Happy2Play said: Something like this. p.appInfo {display: none;} it seems that after the last update, this no longer works
Happy2Play 9811 Posted September 27, 2020 Posted September 27, 2020 (edited) 10 minutes ago, Alexwerilles said: it seems that after the last update, this no longer works I have no issue with it on 4.5.0.50 or 4.6.0.1. This would suggest you have broken code in your custom css box. Edited September 27, 2020 by Happy2Play
Alexwerilles 3 Posted September 27, 2020 Author Posted September 27, 2020 11 minutes ago, Happy2Play said: I have no issue with it on 4.5.0.50 or 4.6.0.1. This would suggest you have broken code in your custom css box. but I haven't changed anything, it's the same as before. Even the "trailers" tab also reappeared, and the image background of the login screen no longer appears (ignore the *** in the url) This is my css: html:root { --theme-primary-color: red; --theme-accent-text-color: red; --theme-primary-color-lightened: red; --theme-icon-focus-background: rgba(255, 0, 0, 0.2); } .custombg { background: url('https:***.jpg'); background-size: cover; -webkit-background-size: cover; -moz-background-size: cover; -o-background-size: cover; height: 100vh; position: fixed; background-position: center center; background-repeat: no-repeat; } / *Remover o nome Emby Web dá pagina de configurações do usuário* / p.appInfo {display: none;} div.mainDrawer-docked h3:nth-child(8) {display: none;} div.dynamicRoutes a:nth-child(-n+3) {display: none !important;} .btnHeaderPremiere { display: none ! important; } a.navMenuOption-selected { background-color: rgba(255,0,0,.2)!important; color: red; } a.emby-tab-button-active {color: red;} input.emby-checkbox:checked+span:before { border-color: red; background-color: red; } a.button-link {color: red;} input.emby-input:focus, .emby-textarea:focus {border-color: red;} button.button-submit:not(.emby-button-tv), button.button-submit:not(.emby-button-tv):focus {background: red;} button.emby-button {outline-color: red;} } div.dynamicRoutes h3:nth-child(7) {display: none;} /*Remove "Emby Web header" on User icon screen*/ div.dynamicRoutes h3:nth-child(9) {display: none;} /*Remove "Emby Web header" on User icon screen*/ div.mainDrawer.scrollY.scrollY-mini.mainDrawer-open-full.mainDrawer-docked h3:nth-child(8) {display: none;} /*Remove Links e informações do vídeo*/ div.linksSection, div.audioVideoMediaInfo {display: none;} /*Remove selecionador de vídeo(não aplicado quando tem mais de uma versão de vídeo*/ div.selectVideoContainer {display: none;} progress.playbackProgress::-webkit-progress-value, progress.playbackProgress::-moz-progress-bar {background-color:red;} /*Remove opções Exibir e Tela Inicio da página de ajustes (perfil)*/ div.mainDrawer-docked a:nth-child(-n+3) {display: none !important;} / * Ocultar upload da câmera * / [ data - collectiontype = "boxsets" ], [ data - id = "165db2549e77c71dacef0e83a95cc5de" ] { display : none ! importante } / *Remover o nome Emby Web dá pagina de configurações, do usuário* / p.appInfo {display: none;} / *Remove My Media* / div.section0 div.sectionTitleContainer {display: none;} / * Remove tab Trailers* / body > div.skinHeader.focuscontainer-x.skinHeader-withBackground.headroom > div > div.headerMiddle.sectionTabs > div > div > button:nth-child(3) = Movies Trailers tab
Happy2Play 9811 Posted September 27, 2020 Posted September 27, 2020 (edited) 12 minutes ago, Alexwerilles said: but I haven't changed anything, it's the same as before. Even the "trailers" tab also reappeared, and the image background of the login screen no longer appears (ignore the *** in the url) This is my css: html:root { --theme-primary-color: red; --theme-accent-text-color: red; --theme-primary-color-lightened: red; --theme-icon-focus-background: rgba(255, 0, 0, 0.2); } .custombg { background: url('https:***.jpg'); background-size: cover; -webkit-background-size: cover; -moz-background-size: cover; -o-background-size: cover; height: 100vh; position: fixed; background-position: center center; background-repeat: no-repeat; } / *Remover o nome Emby Web dá pagina de configurações do usuário* / p.appInfo {display: none;} div.mainDrawer-docked h3:nth-child(8) {display: none;} div.dynamicRoutes a:nth-child(-n+3) {display: none !important;} .btnHeaderPremiere { display: none ! important; } a.navMenuOption-selected { background-color: rgba(255,0,0,.2)!important; color: red; } a.emby-tab-button-active {color: red;} input.emby-checkbox:checked+span:before { border-color: red; background-color: red; } a.button-link {color: red;} input.emby-input:focus, .emby-textarea:focus {border-color: red;} button.button-submit:not(.emby-button-tv), button.button-submit:not(.emby-button-tv):focus {background: red;} button.emby-button {outline-color: red;} } div.dynamicRoutes h3:nth-child(7) {display: none;} /*Remove "Emby Web header" on User icon screen*/ div.dynamicRoutes h3:nth-child(9) {display: none;} /*Remove "Emby Web header" on User icon screen*/ div.mainDrawer.scrollY.scrollY-mini.mainDrawer-open-full.mainDrawer-docked h3:nth-child(8) {display: none;} /*Remove Links e informações do vídeo*/ div.linksSection, div.audioVideoMediaInfo {display: none;} /*Remove selecionador de vídeo(não aplicado quando tem mais de uma versão de vídeo*/ div.selectVideoContainer {display: none;} progress.playbackProgress::-webkit-progress-value, progress.playbackProgress::-moz-progress-bar {background-color:red;} /*Remove opções Exibir e Tela Inicio da página de ajustes (perfil)*/ div.mainDrawer-docked a:nth-child(-n+3) {display: none !important;} / * Ocultar upload da câmera * / [ data - collectiontype = "boxsets" ], [ data - id = "165db2549e77c71dacef0e83a95cc5de" ] { display : none ! importante } / *Remover o nome Emby Web dá pagina de configurações, do usuário* / p.appInfo {display: none;} / *Remove My Media* / div.section0 div.sectionTitleContainer {display: none;} / * Remove tab Trailers* / body > div.skinHeader.focuscontainer-x.skinHeader-withBackground.headroom > div > div.headerMiddle.sectionTabs > div > div > button:nth-child(3) = Movies Trailers tab Your comment broke the code, remove the space. / *Remover o nome Emby Web dá pagina de configurações do usuário* / to /*Remover o nome Emby Web dá pagina de configurações do usuário*/ Don't know if it is a copy and paste issue or a translation issue, but look at all your comments. Plus last line is incomplete. Edited September 27, 2020 by Happy2Play
Alexwerilles 3 Posted September 27, 2020 Author Posted September 27, 2020 7 minutes ago, Happy2Play said: Your comment broke the code, remove the space. / *Remover o nome Emby Web dá pagina de configurações do usuário* / to /*Remover o nome Emby Web dá pagina de configurações do usuário*/ Don't know if it is a copy and paste issue or a translation issue, but look at all your comments. in the custom css box it's normal, without errors. That was just a mistake by the translator when he came here. As I said, I didn’t change anything, it’s the same as before
Alexwerilles 3 Posted September 27, 2020 Author Posted September 27, 2020 8 minutes ago, Happy2Play said: Your comment broke the code, remove the space. / *Remover o nome Emby Web dá pagina de configurações do usuário* / to /*Remover o nome Emby Web dá pagina de configurações do usuário*/ Plus last line is incomplete. '/ * Remove tab Trailers* / ' ? I copied from a topic here in the forum
Happy2Play 9811 Posted September 27, 2020 Posted September 27, 2020 Just now, Alexwerilles said: in the custom css box it's normal, without errors. That was just a mistake by the translator when he came here. As I said, I didn’t change anything, it’s the same as before Removing the spaces your code works on 4.5.0.50 and 4.6.0.1 for me. Have you tested removing all code and only applying this? p.appInfo {display: none;}
Happy2Play 9811 Posted September 27, 2020 Posted September 27, 2020 2 minutes ago, Alexwerilles said: '/ * Remove tab Trailers* / ' ? I copied from a topic here in the forum It is incomplete as you are not telling it to do anything, but trying to remove the trailers tab on Movies will also remove the Upcoming tab on TV Shows as they are both the third child element. Without page ids you can not use css to remove those header elements.
Alexwerilles 3 Posted September 27, 2020 Author Posted September 27, 2020 5 minutes ago, Happy2Play said: Removing the spaces your code works on 4.5.0.50 and 4.6.0.1 for me. Have you tested removing all code and only applying this? p.appInfo {display: none;} Yeah, it just worked. I will reapply the codes, one at a time, until I discover the problem.
Emby Tower 34 Posted October 18, 2020 Posted October 18, 2020 (edited) How can I change the color of the green progress bar during a scan? And the switch in the library setttings for "advanced settings"? Edited October 18, 2020 by Emby Tower
PenkethBoy 2068 Posted October 18, 2020 Posted October 18, 2020 which one? did you try searching for it?
Emby Tower 34 Posted October 18, 2020 Posted October 18, 2020 Just now, PenkethBoy said: which one? did you try searching for it? I've tried to find something in the forum ... I'm talking about the green bar if the library scan is running, visible on the dashboard and inside the library overview.
PenkethBoy 2068 Posted October 18, 2020 Posted October 18, 2020 there are three i think dashboard dashboard>library and scheduled tasks all IIRC require a different css to change the colour
Emby Tower 34 Posted October 18, 2020 Posted October 18, 2020 Then I'm talking about dashboard and dashboard-library ...
PenkethBoy 2068 Posted October 18, 2020 Posted October 18, 2020 have you tried reading this thread all the way through!
Happy2Play 9811 Posted October 18, 2020 Posted October 18, 2020 27 minutes ago, Emby Tower said: Then I'm talking about dashboard and dashboard-library ... /* Google Progress Bars */ progress::-webkit-progress-value { background: #0C57D6 !important; } /* Firefox Progress Bars */ progress::-moz-progress-bar { background: #0C57D6 !important; } https://emby.media/community/index.php?/topic/75856-need-help-with-css-for-slider-color/&do=findComment&comment=769209 Haven't verified other code though as things have changed over time. 1
Alexwerilles 3 Posted October 20, 2020 Author Posted October 20, 2020 On 8/29/2020 at 4:01 PM, Happy2Play said: That is not the same location. One is on the user settings page that is a docked drawer menu. div.mainDrawer.scrollY.scrollY-mini.mainDrawer-open-full.mainDrawer-docked h3:nth-child(8) {display: none;} Hi it seems that it no longer works with the last update
Happy2Play 9811 Posted October 20, 2020 Posted October 20, 2020 29 minutes ago, Alexwerilles said: Hi it seems that it no longer works with the last update div[title="Emby Web"] #expandButton {display: none;}
Magulan 1 Posted October 22, 2020 Posted October 22, 2020 On 8/28/2020 at 4:02 AM, Alexwerilles said: I use Debian. Unfortunately I don't know how to do that Here a small Script to change the Colors on Debian after every Update. Many thanks to Happy2Play for the tip, which can be done by script #!/bin/sh find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/\:green/\:#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#52b54b/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#2bc253/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#54f054/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#5EC157/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#009F00/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#00B32C/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/rgba(82,181,75/rgba(12,87,214/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/rgba(82, 181, 75/rgba(12, 87, 214/g' {} \; cp -a /usr/local/bin/emby-change-color/logowhite.png /opt/emby-server/system/dashboard-ui/modules/themes/logowhite.png service emby-server restart 1
Alexwerilles 3 Posted October 22, 2020 Author Posted October 22, 2020 4 hours ago, Magulan said: Here a small Script to change the Colors on Debian after every Update. Many thanks to Happy2Play for the tip, which can be done by script #!/bin/sh find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/\:green/\:#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#52b54b/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#2bc253/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#54f054/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#5EC157/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#009F00/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/#00B32C/#0C57D6/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/rgba(82,181,75/rgba(12,87,214/g' {} \; find /opt/emby-server/system/dashboard-ui -iregex '.*\.\(css\|js\|json\|html\|txt\)' -exec sed -i -e 's/rgba(82, 181, 75/rgba(12, 87, 214/g' {} \; cp -a /usr/local/bin/emby-change-color/logowhite.png /opt/emby-server/system/dashboard-ui/modules/themes/logowhite.png service emby-server restart Thank you!
Alexwerilles 3 Posted October 22, 2020 Author Posted October 22, 2020 (edited) Does anyone know how I can change the color of the browser address bar, on my phone? The bar turns green when Emby starts. I wanted to make it red or black Edited October 22, 2020 by Alexwerilles
