Alexwerilles 3 Posted August 29, 2020 Author Posted August 29, 2020 1 hour ago, Happy2Play said: That is not the same location. One is on the user settings page that is a docked drawer menu. div.mainDrawer.scrollY.scrollY-mini.mainDrawer-open-full.mainDrawer-docked h3:nth-child(8) {display: none;} Thanks You are the best!
Alexwerilles 3 Posted September 14, 2020 Author Posted September 14, 2020 Does anyone know how I can remove this text?
PenkethBoy 2068 Posted September 14, 2020 Posted September 14, 2020 what page is that? give us something to work with!
Alexwerilles 3 Posted September 14, 2020 Author Posted September 14, 2020 15 minutes ago, PenkethBoy said: que pagina é essa? dê-nos algo com que trabalhar! settings page, user
PenkethBoy 2068 Posted September 14, 2020 Posted September 14, 2020 (edited) .appInfo {display:none} i have not checked if it affects anything else Edited September 14, 2020 by PenkethBoy 1
Happy2Play 9811 Posted September 14, 2020 Posted September 14, 2020 Something like this. p.appInfo {display: none;}
PenkethBoy 2068 Posted September 14, 2020 Posted September 14, 2020 makes a change me beating you to it Happy
Alexwerilles 3 Posted September 14, 2020 Author Posted September 14, 2020 48 minutes ago, Happy2Play said: Something like this. p.appInfo {display: none;} Thank you very much. I want to change the name that keeps appearing on the browser tab. I did everything they said in this tutorial but it hasn't changed. Can you tell me if you have to do anything else now? https://emby.media/community/index.php?/topic/79828-emby-tab-name-and-slim-drawer-slider/&/topic/79828-emby-tab-name-and-slim-drawer-slider/
Happy2Play 9811 Posted September 14, 2020 Posted September 14, 2020 7 minutes ago, Alexwerilles said: Thank you very much. I want to change the name that keeps appearing on the browser tab. I did everything they said in this tutorial but it hasn't changed. Can you tell me if you have to do anything else now? Sorry I followed the exact same steps. https://emby.media/community/index.php?/topic/79828-emby-tab-name-and-slim-drawer-slider/&do=findComment&comment=812968
Alexwerilles 3 Posted September 14, 2020 Author Posted September 14, 2020 1 minute ago, Happy2Play said: Sorry I followed the exact same steps. https://emby.media/community/index.php?/topic/79828-emby-tab-name-and-slim-drawer-slider/&do=findComment&comment=812968 I redid 3 times and nothing
Alexwerilles 3 Posted September 14, 2020 Author Posted September 14, 2020 (edited) I redid it again and it worked. Edited September 14, 2020 by Alexwerilles
arrbee99 1836 Posted September 16, 2020 Posted September 16, 2020 I think it got mentioned earlier somewhere but would anyone know how to make the two green bits blue, the red bits blue and the blue bits a different blue. I tried with .span and .progress and stuff, but got nowhere. Thanks again.
Happy2Play 9811 Posted September 16, 2020 Posted September 16, 2020 12 minutes ago, arrbee99 said: I think it got mentioned earlier somewhere but would anyone know how to make the two green bits blue, the red bits blue and the blue bits a different blue. I tried with .span and .progress and stuff, but got nowhere. Thanks again. Running task color #divRunningTasks.paperList p span {color: blue !important;} Update to date check box #pUpToDate i {background-color: blue !important;} Now alerts is a script that only shows Red on Failure so it can only be changes in the script or you will have the same color no matter the Alert type with css. At least I have not found a way to allow it to work properly with css. You have to change the color via the script. But if you don't care then here div.listItemImageContainer-round.defaultCardBackground {background-color: blue !important;}
Happy2Play 9811 Posted September 16, 2020 Posted September 16, 2020 52 minutes ago, arrbee99 said: and the blue bits a different blue What do you mean? The running task progress indicator?
arrbee99 1836 Posted September 16, 2020 Posted September 16, 2020 (edited) 17 minutes ago, Happy2Play said: What do you mean? The running task progress indicator? Yes. The dark blue bar under Refresh Internet Channels in this case. (and hopefully that green text / percent next to it). Edit - I guess the first one you did 'Running Task Color' was for the green percent thing... Edited September 16, 2020 by arrbee99
Happy2Play 9811 Posted September 17, 2020 Posted September 17, 2020 (edited) 1 hour ago, arrbee99 said: Yes. The dark blue bar under Refresh Internet Channels in this case. (and hopefully that green text / percent next to it). Edit - I guess the first one you did 'Running Task Color' was for the green percent thing... Yes, Text is covered above. Are you saying you want the Dashboard progress bar value to be different on the dashboard vs other areas? Example would be Dashboard and Library for library scan. Edited September 17, 2020 by Happy2Play
arrbee99 1836 Posted September 17, 2020 Posted September 17, 2020 Well, I managed to get the bars under Scheduled tasks to change to blue, and would prefer this to be the same shade (or I think I would anyway). And this seems to have become blue anyway -
Happy2Play 9811 Posted September 17, 2020 Posted September 17, 2020 7 minutes ago, arrbee99 said: Well, I managed to get the bars under Scheduled tasks to change to blue, and would prefer this to be the same shade (or I think I would anyway). And this seems to have become blue anyway - Not sure where different shading would apply if you applying same color to these locations. Can you post or pm all the code you are using.
PenkethBoy 2068 Posted September 17, 2020 Posted September 17, 2020 how would you change the colour of the 27.7% text on the end?
arrbee99 1836 Posted September 17, 2020 Posted September 17, 2020 14 minutes ago, Happy2Play said: Not sure where different shading would apply if you applying same color to these locations. Can you post or pm all the code you are using. This seemed to work. Might not be correct but seemed to work. /*Make Scheduled Tasks Progress Bar Blue*/ div.taskProgressInner {background-color: #5d7e9b;}
arrbee99 1836 Posted September 17, 2020 Posted September 17, 2020 10 minutes ago, PenkethBoy said: how would you change the colour of the 27.7% text on the end? Happy2play provided this, which you might have seen anyway - #divRunningTasks.paperList p span {color: blue !important;}
PenkethBoy 2068 Posted September 17, 2020 Posted September 17, 2020 ah only works on dashboard page not sch task page which is where i was looking
Happy2Play 9811 Posted September 17, 2020 Posted September 17, 2020 15 minutes ago, PenkethBoy said: how would you change the colour of the 27.7% text on the end? Just now, PenkethBoy said: ah only works on dashboard page not sch task page which is where i was looking Currently still looking.
PenkethBoy 2068 Posted September 17, 2020 Posted September 17, 2020 looks like something like div.taskProgressOuter - although not having any luck with that
Happy2Play 9811 Posted September 17, 2020 Posted September 17, 2020 32 minutes ago, PenkethBoy said: how would you change the colour of the 27.7% text on the end? 12 minutes ago, PenkethBoy said: looks like something like div.taskProgressOuter - although not having any luck with that Something like this for Scheduled Tasks percentage complete div.scheduledTaskPaperIconItem[data-status="Running"] span {color: red;}
