Antonio_Ticsa 3 Posted August 27, 2020 Posted August 27, 2020 Hola AMIGOS. Una pregunta Emby cuenta con alguna extensión para mandar mensaje. Que el usuario se comunique con el administrador porque solo puedo mandar mensajes a los usuarios pero no pueden responderme. También conocen de un plugin de reloj: 1)Como un reloj de salvapantalla 2)También se pueda poner alarmas como un reloj normal Saludos
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 Hi, It's not possible for the user to send a message back. The communication is one way from the console to the client. It's meant for being able to send a message to someone. "Time for Dinner", "Resetting server try again in 5 minute" type quick messages.
Antonio_Ticsa 3 Posted August 27, 2020 Author Posted August 27, 2020 Hola cayars anotado Pero lo del reloj También conocen de un plugin de reloj: 1)Como un reloj de salvapantalla 2)También se pueda poner alarmas como un reloj normal Saludos
Luke 42240 Posted August 27, 2020 Posted August 27, 2020 @cayars can you rename his topics appropriately. Thanks.
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 1 minute ago, Luke said: @ cayars can you rename his topics appropriately. Thanks. No mod privs so I can't rename things.
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 1 hour ago, Antonio_Ticsa said: Hello Cayars noted But about the clock They also know of a clock plugin: 1) Like a screensaver clock 2) You can also set alarms like a normal clock Regards You could make a request in the "request" section of the forum for the clock screen saver. Something like this could be done in the future. I would doubt there would be anything we could do as far as alarms go. What did you have in mind with that functionality?
Happy2Play 9811 Posted August 28, 2020 Posted August 28, 2020 1 hour ago, cayars said: No mod privs so I can't rename things. What should it be?
Carlo 4561 Posted August 28, 2020 Posted August 28, 2020 12 hours ago, Happy2Play said: What should it be? Not sure since it's 3 different requests. How about "Request: Clock, Alarms, and two-way messaging" ??? 1
