naterade 0 Posted August 27, 2020 Posted August 27, 2020 i cannot connect remotely, ive tried all the trouble shooting tips on the github, and none of them work, my web browser shows problem loading page, android app says cannot connect to server
Luke 42210 Posted August 27, 2020 Posted August 27, 2020 Hi there, I would suggest checking out our Connection Troubleshooter: https://support.emby.media/support/solutions/articles/44001849007-connectivity Please go through this and let us know which steps succeed and which ones do not. Thanks !
naterade 0 Posted August 27, 2020 Author Posted August 27, 2020 all work except the port forwarding i have configured it in my modem and it still does not work
Carlo 4561 Posted August 28, 2020 Posted August 28, 2020 If you look at the IP shown in your firewall for the WAN address, does that IP match what Canyouseeme says?
Guest Posted August 28, 2020 Posted August 28, 2020 Fwd what @cayars said. If cys.org says your port is open But it still does not work try manually opening another port like 8097 and map emby to it via its settings. That worked for me.
