Craige 1 Posted August 27, 2020 Posted August 27, 2020 My question is straightforward, how can i know what Resolution & Audio format is playing currently on my TV. Some hidden console/codes or anything ? PS: i am on 4K Fire Tv Stick.
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 He Craige, While playing back your video click the cog icon and then select Stats for Nerds. That will give you a lot of information about the media currently playing back.
Craige 1 Posted August 27, 2020 Author Posted August 27, 2020 58 minutes ago, cayars said: He Craige, While playing back your video click the cog icon and then select Stats for Nerds. That will give you a lot of information about the media currently playing back. There is no cog icon !!! Only options to change audio,subs, watch from begining. And, then there is X-ray feature - Nothing else.
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 From first post 2 hours ago, Craige said: PS: i am on 4K Fire Tv Stick.
Luke 42246 Posted August 27, 2020 Posted August 27, 2020 That's the device. What app is playing video?
Craige 1 Posted August 28, 2020 Author Posted August 28, 2020 Lol what is going on here ? What App ? Guess my English is horrible !
Luke 42246 Posted August 28, 2020 Posted August 28, 2020 Yes. What app on the fire stick are you using?
Craige 1 Posted August 29, 2020 Author Posted August 29, 2020 22 hours ago, Luke said: Yes. What app on the fire stick are you using? Got it what u asked ! Using Prime video (defualt) app
Carlo 4561 Posted August 29, 2020 Posted August 29, 2020 Hi, You would likely need to ask Amazon how to do that in their software. But in the Emby app you can bring up Stats for Nerds during playback (cog icon during playback) and it will give you this info.
