Craige 1 Posted August 27, 2020 Posted August 27, 2020 I am eyeing a Shiny New 4K TV and here i came across one thing which i cant seem to understand. I am interested in Samsung Q80T QLED (2020 Model) and some models supports "Dolby 5.1 Decoder" and some models don't.What exactly is this and it can affect me in my Listening experience ? NOTE: All models supports Dolby Digital + (As clearly stated in Specs on website)
FrostByte 5453 Posted August 27, 2020 Posted August 27, 2020 All Samsung TVs should have a Dolby decoder used for playback of lossy Dolby formats. Which one do you see that doesn't have a DD decoder? According to the Samsung developer's page all premium and standard sets support Dolby Digital/AC3 and Dolby Digital Plus/EAC3 playback https://developer.samsung.com/smarttv/develop/specifications/media-specifications/2020-tv-video-specifications.html If you look at page 126 of the Q80T user manual you can see it has a Dolby Digital decoder https://downloadcenter.samsung.com/content/UM/202006/20200618112841534/NIKATSCT-3.0.7_EM_NIKE_USA_ENG_200527.0.pdf I have read though that the models with eARC may get a firmware update for Dolby TrueHD (lossless) playback
Craige 1 Posted August 28, 2020 Author Posted August 28, 2020 (edited) 21 hours ago, FrostByte said: All Samsung TVs should have a Dolby decoder used for playback of lossy Dolby formats. Which one do you see that doesn't have a DD decoder? This Model (49") that i want doesn't support the decoder as they omited tht info. (Check Specs - under Audio) : https://www.samsung.com/in/tvs/qled-tv-q80t/QA49Q80TAKXXL/ Rest in same series all models 55", 65" etc supports the decoder. See: https://www.samsung.com/in/tvs/qled-tv-q80t/QA55Q80TAKXXL/ Please Englighten me as to how it will affect me. Edited August 28, 2020 by Craige
FrostByte 5453 Posted August 28, 2020 Posted August 28, 2020 (edited) It says it supports Dolby Digital Plus, but I don't see anywhere on that link where it says it doesn't support Dolby Digital. That's just like a TV manufacturer saying it supports Dolby Atmos, but that doesn't mean it doesn't support anything else. The reason they listed Dolby Digital Plus on that page is because companies like Netflix stream a lot of their content using DD+ You need to download the e-manual linked on the page you just posted and look at page 132. It lists all the supported codecs right there in the far right column. Dolby Digital is the very first one listed. https://downloadcenter.samsung.com/content/UM/202008/20200811110229972/NIKDVBADT-3.0.0_EM_NIKE_ASIA_ENG_200629.0.pdf Here is a list of audio codecs from that TV you linked that it will support using Emby Dolby Digital LPCM ADPCM(IMA, MS) AAC HE-AAC WMA Dolby Digital+ MPEG(MP3) AC-4 G.711(A-Law, μ-Law) OPUS However, if it didn't have a Dolby Digital decoder then you wouldn't get any sound from a movie that had an AC3 track unless Emby converted it on the fly. Edited August 28, 2020 by FrostByte
Craige 1 Posted August 28, 2020 Author Posted August 28, 2020 (edited) 49 minutes ago, FrostByte said: However, if it didn't have a Dolby Digital decoder then you wouldn't get any sound from a movie that had an AC3 track unless Emby converted it on the fly. I understand what u saying. But the way its mentioned by Samsung All their 55"+ models have added benefit of "Dolby 5.1 Decoder" Support, which is very weird. EDIT: Attaching Screenshot. 55" 49" Edited August 28, 2020 by Craige 1
FrostByte 5453 Posted August 28, 2020 Posted August 28, 2020 That does make it confusing when they do that because most people probably just read the specs sheet for comparison before buying and not the big user manual. 1
crueDE 0 Posted November 30, 2024 Posted November 30, 2024 On 8/28/2020 at 7:46 PM, FrostByte said: That does make it confusing when they do that because most people probably just read the specs sheet for comparison before buying and not the big user manual. Hey FrostByte, I have a very similar question. I compared the Samsung QN90D with the QN92D. At first I thought the only difference is the stand color, but then I saw on the Samsung Store page that the QN90D has a "Dolby Decoder 5.1 channel" and the QN92D has a "Dolby Decoder 2 channel". Would you say that is an error? In the 2024 manual I can only find a 5.1 channel Dolby Digital+ decoder. I have a 5.1 channel 2015 Denon and will connect it via ARC to the TV. Would the 2 channel decoder cause problems in that case?
