hifiaudio2 48 Posted August 26, 2020 Posted August 26, 2020 EMBY is my main use for the shield so I'd like to set all shield settings as perfect for emby as possible. Color space settings, resolution settings, etc.
rliepins 9 Posted August 27, 2020 Posted August 27, 2020 I'd read this if there was one, especially settings for Live TV and transcoding
ebr 16338 Posted August 28, 2020 Posted August 28, 2020 Defaults are usually the best option. Most of the rest of it will come down to personal equipment, setup and preference.
hifiaudio2 48 Posted August 28, 2020 Author Posted August 28, 2020 I might should reframe my question. I'm wondering about the settings on the shield that are best for Emby. Not settings within the app. Like choosing 59 or 23 Hertz refresh, allowing it to do auto color space / rec 2020 versus rec 709, ETC.
vdatanet 1619 Posted August 31, 2020 Posted August 31, 2020 This is a question for advanced users with very fine eyesight, playing 1080i content on the Shield 2019 Pro, which is better: Deinterlace on the server to be able to apply AI upcaling Deinterlace on the client, but then the content is not compatible with AI upcaling I do not see differences, but perhaps an expert can say something about this.
Carlo 4561 Posted August 31, 2020 Posted August 31, 2020 I've not tried this as I do my conversions "off line" to progressive from interlaced. But if you can't tell the difference I'd just have the client handle it so the server doesn't have to do any transcoding.
rbjtech 5345 Posted September 2, 2020 Posted September 2, 2020 (edited) A setting frequently missed (as peoples screen shots of issues shows in 'Stats for Nerds'..) is the frame rate matching option - which is off by default. If your TV refresh can match the source (which on any modern TV in the last 10 years should be able to do) then this should be switched on - resulting in much smoother 'panning' and less 'juddering' in films. Modern TV's do a much better job then they used to with 'pulldown' (trying to match the video frame rate to the TV) but it is still much better to just refresh at the Native refresh rate if you have the option. The downside is you might see the screen 'blank' for a fraction of a second when switching back to the Emby menu's. Edited September 2, 2020 by rbjtech 1
vdatanet 1619 Posted September 2, 2020 Posted September 2, 2020 And what about resolution match option? 1
rbjtech 5345 Posted September 2, 2020 Posted September 2, 2020 (edited) 13 minutes ago, vdatanet said: And what about resolution match option? I'm not 100% on what this actually does haha. I *think* Emby will try and use the TV supported resolutions to avoid the TV having to scale. Perhaps @ebr could advise further on this one ? Edited September 2, 2020 by rbjtech
ebr 16338 Posted September 2, 2020 Posted September 2, 2020 3 hours ago, rbjtech said: I'm not 100% on what this actually does haha. I *think* Emby will try and use the TV supported resolutions to avoid the TV having to scale. Perhaps @ebr could advise further on this one ? If selected, it will switch to a mode with a resolution that matches the content. If not, it will leave the resolution the same and look for a mode with just the proper frame rate. Yes, this is for those that want their TV to do scaling instead of the Android device. 1 1
