ThiagoArau 0 Posted January 9, 2021 Author Posted January 9, 2021 Gostaria de mais uma ajuda! Possuo uma conta ativa do emby premiere e preciso saber qual seria uma boa configuração para que fique sem travamentos, tem amigos meus com 10mb de internet e que não conseguem assistir direito, nem filmes e nem séries, sempre fica travando ou em péssima qualidade, e o iptv tbm, instalei o plugin de iptv e coloquei uma lista m3u na tv ao vivo, eles mla consegue assistir os canais de iptv o canal fecha com 2 ou 3 minutos de reprodução, possuo em minha máquina 40mb de upload. o que preciso configurar para poder ter uma reprodução limpa dos filmes, séries e iptv?
Carlo 4561 Posted January 9, 2021 Posted January 9, 2021 So give us an overview of the machine/network where you have Emby Server installed on. Where the server is located what is the UPLOAD bandwidth. You will want a minimum of 5 to 10 Mb per simultaneous user you want to support. You will also need to check to make sure you media has been converted to fit in this 5 to 10Mb bandwidth or else you'll have to transcode streams. If you REALLY want to support 100 or so users you have to stop thinking about running a home server and think production servers setup like what would be used on Netflix or Prime for media with multiple resolutions and bitrates ready to stream AS IS. You're talking decent $ on hardware and storage do to this and usually this isn't warranted for a home/friends setup which is what Emby is designed for. You will also need to upgrade your Premiere License to hand the total number of devices you will allow your users to use. The default license is for 25 devices but we have others and you can easily upgrade to 1000 or more devices if needed. You also need to review our licensing and TOS to make sure you use is legal and not a violation of our software license.
ThiagoArau 0 Posted January 9, 2021 Author Posted January 9, 2021 1 hour ago, cayars said: Portanto, dê-nos uma visão geral da máquina / rede em que o Emby Server está instalado. Onde o servidor está localizado, qual é a largura de banda do UPLOAD. Você vai querer um mínimo de 5 a 10 Mb por usuário simultâneo que deseja oferecer suporte. Você também precisará verificar se sua mídia foi convertida para caber nessa largura de banda de 5 a 10 Mb ou você terá que transcodificar os fluxos. Se você REALMENTE quiser oferecer suporte a cerca de 100 usuários, precisa parar de pensar em executar um servidor doméstico e pensar na configuração dos servidores de produção como o que seria usado no Netflix ou Prime para mídia com múltiplas resoluções e taxas de bits prontas para transmitir COMO ESTÃO. Você está falando de $ em hardware e armazenamento decentes para isso e geralmente isso não é garantido para uma configuração de casa / amigos que é para o que Emby foi projetado. Você também precisará atualizar sua Licença Premiere para fornecer o número total de dispositivos que permitirá que seus usuários usem. A licença padrão é para 25 dispositivos, mas temos outros e você pode facilmente atualizar para 1000 ou mais dispositivos, se necessário. Você também precisa revisar nosso licenciamento e TOS para ter certeza de que seu uso é legal e não uma violação de nossa licença de software. UPLOAD - I hired 50mbs but it is oscillating between 40 and 50mbs; today I have about 10 users but it is usually 3 to 4 simultaneously, how would the configuration of production servers be? my emby license is monthly!
ThiagoArau 0 Posted January 9, 2021 Author Posted January 9, 2021 I downloaded several movies and series in the mkv format, but I saw a lot of difficulty with some users and started converting to the mp4 format using ffmpeg and even so not all managed to have a clean reproduction, they had to lower the quality to a 720p-1mbs format . do I need to activate any transcoding settings? I'm also having a lot of difficulty with the iptv plugin, when it starts playing it for about 2 minutes of playback and goes back to the channel screen. I put the m3u list on live tv and it continued the same way. is there any configuration for this not to happen?
Carlo 4561 Posted January 9, 2021 Posted January 9, 2021 5 hours ago, ThiagoArau said: UPLOAD - I hired 50mbs but it is oscillating between 40 and 50mbs; today I have about 10 users but it is usually 3 to 4 simultaneously, how would the configuration of production servers be? my emby license is monthly! So if you always have 40mb available and let's say 4 streams needing that bandwidth you could allocate 40/4=10Mbps to each user which you setup on the server for each user.
Carlo 4561 Posted January 9, 2021 Posted January 9, 2021 5 hours ago, ThiagoArau said: I downloaded several movies and series in the mkv format, but I saw a lot of difficulty with some users and started converting to the mp4 format using ffmpeg and even so not all managed to have a clean reproduction, they had to lower the quality to a 720p-1mbs format. do I need to activate any transcoding settings? I'm also having a lot of difficulty with the iptv plugin, when it starts playing it for about 2 minutes of playback and goes back to the channel screen. I put the m3u list on live tv and it continued the same way. is there any configuration for this not to happen? Would need to have more information about these other situations and it's unrelated to external access or bandwidth so please open different topics for these issues so each thread can concentrate on one issue.
ebr 16354 Posted January 9, 2021 Posted January 9, 2021 10 hours ago, ThiagoArau said: today I have about 10 users I would think that is your issue. Each user is only going to be able to get about 2-3Mb streams. And, if the first few that connected are streaming at 10+ then the last six or so are going to get horrible results.
ThiagoArau 0 Posted January 11, 2021 Author Posted January 11, 2021 On 09/01/2021 at 10:27, ebr said: Eu acho que esse é o seu problema. Cada usuário só será capaz de obter fluxos de 2-3 Mb. E, se os primeiros poucos conectados estiverem transmitindo a 10+, os últimos seis ou mais obterão resultados horríveis. Certo, porém já aconteceu de ficar travando na casa da minha namorada e quando eu olhei n servidor para verificar se algum amigo meu estava assistindo algo e não ter ninguém, somente eu e ficou travando muito. você sabe qual seria o melhor formato de vídeo e áudio para que isso não se repita mais?
Carlo 4561 Posted January 11, 2021 Posted January 11, 2021 It's possible you have ISP throttling or quality shaping going on that's out of your control. This could be on either side. I'd try accessing your Emby Server from a different location using a different ISP and see if you have the same result. It's going to be a process of elimination.
epereira 0 Posted February 15, 2022 Posted February 15, 2022 On 09/01/2021 at 06:09, cayars said: Portanto, se você sempre tiver 40 MB disponíveis e digamos 4 fluxos precisando dessa largura de banda, você poderá alocar 40/4 = 10 Mbps para cada usuário que você configurar no servidor para cada usuário. Essa resposta chamou minha atenção. "alocar 40/4 = 10 Mbps para cada usuário" Esses 10Mbps ajusto na conta do usuário?
Carlo 4561 Posted February 15, 2022 Posted February 15, 2022 Keep in mind when ever you apply limits you're trading bandwidth for transcoding. So if you have a GPU that can handle multiple transcodes this works well. If you don't have a GPU and can't transcode (ie many NAS boxes) then this isn't a good solution. But it's just pure math. Take the amount of usable bandwidth you can count on having (your upload bandwidth at the server side) and divide it by the number of streams you want to simultaneously handle. While you could go lower 8 to 10 Mbps is likely the lowest you would want to use for HD as lowering the amount past that will often times require the resolution to drop past HD and quality degrades a lot. But it's all configurable to each admin's needs so they can setup it up to fit their environment.
