Happy2Play 9814 Posted August 27, 2020 Posted August 27, 2020 1 minute ago, chef said: Okay, so it sounds like using "AlbumArtists" could be legacy API. I'll be right back! This make sense Quote 'artist' is the artist or even several artists of given track. 'album artist' is the pseudo-artist of whole album.
chef 3811 Posted August 27, 2020 Posted August 27, 2020 1 minute ago, Happy2Play said: This make sense I see, it's like the bands name as opposed to the members of the band. What should return? The bands name, maybe?
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 I'm still seeing a bit strange behavior. I want to make sure I'm running the latest version. What should the version number say when looking at your installed plugins?
Happy2Play 9814 Posted August 27, 2020 Posted August 27, 2020 3 minutes ago, cayars said: I'm still seeing a bit strange behavior. I want to make sure I'm running the latest version. What should the version number say when looking at your installed plugins? What version do you have, I have 1.0.40.0 that auto updated today.
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 Mine says 3.0.0.2 and is the latest ZIP posted here in the forum. That's why I asked because you mentioned 1.0.40.0 So what should we be testing? From the thread zip or from the catalog?
Happy2Play 9814 Posted August 27, 2020 Posted August 27, 2020 15 minutes ago, chef said: I see, it's like the bands name as opposed to the members of the band. What should return? The bands name, maybe? trying to remember what this report showed previously, but I would think it should show all Artists. In theory Album shows AlbumArtist. 1
Happy2Play 9814 Posted August 27, 2020 Posted August 27, 2020 (edited) 1 minute ago, cayars said: Mine says 3.0.0.2 and is the latest ZIP posted here in the forum. That's why I asked because you mentioned 1.0.40.0 So what should we be testing? From the thread zip or from the catalog? They are supposedly the same (at least the version I got PM'd with that version number) but I would be testing the catalog version. Edited August 27, 2020 by Happy2Play
chef 3811 Posted August 27, 2020 Posted August 27, 2020 Does this return AlbumArtist info as expected? EmbyReports.zip
chef 3811 Posted August 27, 2020 Posted August 27, 2020 5 minutes ago, cayars said: Mine says 3.0.0.2 and is the latest ZIP posted here in the forum. That's why I asked because you mentioned 1.0.40.0 So what should we be testing? From the thread zip or from the catalog? Luke would have increased the version to add to the catalog. I'll try and rectify that to make things less confusing.
Carlo 4561 Posted August 27, 2020 Posted August 27, 2020 Just installed the catalog version and it's much better. 1
Happy2Play 9814 Posted August 27, 2020 Posted August 27, 2020 8 minutes ago, chef said: Does this return AlbumArtist info as expected? EmbyReports.zip 108.62 kB · 0 downloads I see no change in this version Artists Report is empty
chef 3811 Posted August 27, 2020 Posted August 27, 2020 1 minute ago, Happy2Play said: I see no change in this version Artists Report is empty Okay, The endpoint routine gets split, once the request is made, into a couple different switch statements. I have to trace it back to the proper return data to figure out what might need to be updated. The reports API is quite large 1
Happy2Play 9814 Posted August 27, 2020 Posted August 27, 2020 Doesn't appear many of the original posters have been active lately to confirm resolution. @Spaceboy since we appear to have found the right combination of plugins to reproduce the issue, did update 1.0.40.0 resolve your issue?
bugmafia007 12 Posted September 7, 2020 Posted September 7, 2020 (edited) On 8/26/2020 at 1:49 AM, Happy2Play said: @Smaky @chef @kendoman96 @Spaceboy @Supacat @bugmafia007 @koelner21 Do all of you have the Movie Theme Video plugin installed also? yes i have it installed ..but not working properly Edited September 7, 2020 by bugmafia007
Happy2Play 9814 Posted September 7, 2020 Posted September 7, 2020 Just now, bugmafia007 said: yes i have it install ..but not working properly Can you elaborate?
Carlo 4561 Posted September 7, 2020 Posted September 7, 2020 26 minutes ago, bugmafia007 said: yes i have it installed ..but not working properly What exactly isn't working? Do you by any chance see something that resembles 2 screens overlapped? If so go to the Plugin Catalog and update your Reports Plugin.
chef 3811 Posted September 7, 2020 Posted September 7, 2020 The query for baseItems in the plugin is fairly typical. I'm not sure why theme videos would cause an issue. Do you guys mean, when using theme videos as a filter, the plugin is broken?
Happy2Play 9814 Posted September 7, 2020 Posted September 7, 2020 1 minute ago, chef said: The query for baseItems in the plugin is fairly typical. I'm not sure why theme videos would cause an issue. Do you guys mean, when using theme videos as a filter, the plugin is broken? I don't use Theme videos plugin, but having it installed produced the issue in this topic. But your updates resolved that issue, so we are trying to find out what issues @bugmafia007 is having. 2
Luke 42255 Posted September 7, 2020 Posted September 7, 2020 50 minutes ago, Happy2Play said: I don't use Theme videos plugin, but having it installed produced the issue in this topic. That's great investigation, sounds like we finally have an answer to this.
Happy2Play 9814 Posted September 7, 2020 Posted September 7, 2020 4 minutes ago, Luke said: That's great investigation, sounds like we finally have an answer to this. It was all @cayars https://emby.media/community/index.php?/topic/89337-reports-plugin-not-woking/&do=findComment&comment=916882 1
Happy2Play 9814 Posted September 7, 2020 Posted September 7, 2020 @chef since the update went into the catalog can you remove the zips in your posts to prevent confusion and issues via version number.
Smaky 131 Posted September 18, 2020 Author Posted September 18, 2020 I have been a bit busy with work lately.. Now version 1.0.40.0 is working fine. Have not tested it thoroughly but the interface renders properly. Thanks for taking care of this aged request! 2
