ebr 16346 Posted July 8, 2020 Posted July 8, 2020 Sorry, thought he was trying to report a post in the forum...
bugmafia007 12 Posted July 8, 2020 Posted July 8, 2020 (edited) so @ebr what is the solution,i need so much that report(more than 10000 movies here lool) ..if the report doesn't work..what other solutions u can give me?because reports have the same importance like the server himself . Thank You Edited July 8, 2020 by bugmafia007
Spaceboy 2573 Posted July 8, 2020 Posted July 8, 2020 So wait a second @Spaceboy ..so nobody care about this issue? Well you saw how long it was since the dev was first notified of the problem
koelner21 4 Posted July 10, 2020 Posted July 10, 2020 Unfortunately, I have exactly the same problem. I think it's the button, because it used to look different. It would be really nice if someone could update it, because I couldn't find a version for it on Jellyfin. For Slack there is an alternative, but not for Reports Thanks.
Happy2Play 9814 Posted July 10, 2020 Posted July 10, 2020 The issue has not been identified as this affects select system setups and has been that way for awhile. https://emby.media/community/index.php?/topic/74344-reports-plugin-not-working/ Pretty sure there are others but all may have been merged. The plugin is community base so anyone with the coding knowledge can attempt to fix the problem.
koelner21 4 Posted July 10, 2020 Posted July 10, 2020 Unfortunately I am not a programmer, my area of expertise is controlling and accounting. But it seems that several people have the same problem, because I get the same results as the other users. Synology NAS DS418Play mit der aktuellen stable Emby Version 4.4.3.0 Reports wurde aktualisiert 10.7.2020, 23:13:41 Version 1.0.38 If you can set somewhere that the updates are not installed or if someone knows where to get the dll file from, then I would test if an old version works.
Happy2Play 9814 Posted July 11, 2020 Posted July 11, 2020 (edited) If you were to change the drop down from Album to Movies does it make any difference? Or is the drop down blank? But as everyone else that sees this issues it appears to hang and display the same thing, but still can not fully reproduce it. Edited July 11, 2020 by Happy2Play
koelner21 4 Posted July 11, 2020 Posted July 11, 2020 I already had the black screen, too. I have re-started the server several times and also installed other versions. Nothing helps.
Happy2Play 9814 Posted July 11, 2020 Posted July 11, 2020 2 minutes ago, koelner21 said: I already had the black screen, too. I have re-started the server several times and also installed other versions. Nothing helps. What about the Albums drop down, not the three dot menu?
koelner21 4 Posted July 11, 2020 Posted July 11, 2020 1 minute ago, Happy2Play said: What about the Albums drop down, not the three dot menu? Do you mean this one?
Happy2Play 9814 Posted July 11, 2020 Posted July 11, 2020 Yes, basically it looks like these select systems/configurations are not allowing the script to build the content type tables. So if you change that dropdown to something else the same happens correct? Are there any browser console error?
Happy2Play 9814 Posted July 12, 2020 Posted July 12, 2020 No as that the reports.html, the issue is being able to reproduce to figure out where the issue is. Are there any browser console errors when you enter or try to navigate in the plugin?
koelner21 4 Posted July 12, 2020 Posted July 12, 2020 AnyDesk or Teamviewer? Than you can look. I think this will be the easiest way
Luke 42255 Posted July 20, 2020 Posted July 20, 2020 @koelner21 I've merged your topic into the original one as it is discussing the same issue. Thanks.
Carlo 4561 Posted August 25, 2020 Posted August 25, 2020 There seems to be an issue regardless of browser used with the Reports Plugin in 4.5.0.21. It superimpose the Reports startup screen on whatever screen was there to begin with. @Happy2Play please merge my posting into the existing topic.
Happy2Play 9814 Posted August 25, 2020 Posted August 25, 2020 (edited) 2 hours ago, cayars said: There seems to be an issue regardless of browser used with the Reports Plugin in 4.5.0.21. It superimpose the Reports startup screen on whatever screen was there to begin with. @Happy2Play please merge my posting into the existing topic. This is a long standing issue that shouldn't have anything to do with this beta. Now if you are talking about something different then let up know. oops looks like i merged the wrong way, should be fixed now except for who ever was following this topic. Edited August 25, 2020 by Happy2Play
Carlo 4561 Posted August 25, 2020 Posted August 25, 2020 I figured out how to reproduce this at will. For me install the 4 Movie & TV theme plugins by radeon from the catelog will produce the error on my test system. @Luke I believe this is caused by two cookies: _octo .github.com/ _ga .github.com/ I'm correct it should be an easy fix with the "SameSite" attribute in the cookie. But regardless of the cause (didn't look that much) it dies in alameda.js in this function on the fetch line at the very bottom. I also get a couple other errors as well but I think this may be the cause. It could very well be something in any one of the 4 radeon plugins that's responsible. But this may give you hints on how to reproduce it in .21 beta like I'm doing. function getFetchPromise(request, signal) { var headers = request.headers || {}; "json" === request.dataType && (headers.accept = "application/json"); var fetchRequest = { headers: headers, method: request.type, credentials: "same-origin" }; if (request.timeout) { var abortController = new AbortController , boundAbort = abortController.abort.bind(abortController); signal && signal.addEventListener("abort", boundAbort), setTimeout(boundAbort, request.timeout), signal = abortController.signal } signal && (fetchRequest.signal = signal); var contentType = request.contentType; return request.data && ("string" == typeof request.data ? fetchRequest.body = request.data : (fetchRequest.body = paramsToString(request.data), contentType = contentType || "application/x-www-form-urlencoded; charset=UTF-8")), contentType && (headers["Content-Type"] = contentType), fetch(request.url, fetchRequest) } 1
Happy2Play 9814 Posted August 25, 2020 Posted August 25, 2020 10 minutes ago, cayars said: I figured out how to reproduce this at will. For me install the 4 Movie & TV theme plugins by radeon from the catelog will produce the error on my test system. Looks like you found the culprits as I it is reproducible with these plugins installed. Nothing to do with beta as this happens on stable 4.4.3.0 with these plugins installed. Will do a little more testing. @Luke
Carlo 4561 Posted August 25, 2020 Posted August 25, 2020 I just haven't made time to see if it's actually a cookie problem which one or more of the other plugins could be setting incorrectly causing Reports to fail or something else. Easy enough to figure this out and see if it's just one plugin or all 4 that cause the issue.
Happy2Play 9814 Posted August 25, 2020 Posted August 25, 2020 Tagging @radeon as a fyi 10 minutes ago, cayars said: Easy enough to figure this out and see if it's just one plugin or all 4 that cause the issue. tested per plugin (only one at a time) TV theme song - Reports still worked TV theme video - Reports still worked Movie theme song - Reports still worked Movie theme video - Reports stopped working So with this test it would appear to a conflict with Reports and Movie Theme Videos. This test was done in 4.4.3.0 Reports v1.0.39.0 Movie Theme Videos v1.7.5.0
Happy2Play 9814 Posted August 25, 2020 Posted August 25, 2020 here is the console error when clicking Reports with Movie Theme Videos installed. index.html#!/configurationpage?name=reports:1 Uncaught (in promise) Error: Load failed: configurationpage?name=reportsjs: http://localhost:8096/web/configurationpage?name=reportsjs&v=4.4.3.0 at HTMLScriptElement.<anonymous> (alameda.js:1) Promise.then (async) ViewManager.loadView @ viewmanager.js?v=4.4.3.0:1 (anonymous) @ router.js?v=4.4.3.0:1 (anonymous) @ router.js?v=4.4.3.0:1 Promise.then (async) loadContentUrl @ router.js?v=4.4.3.0:1 (anonymous) @ router.js?v=4.4.3.0:1 onInitComplete @ router.js?v=4.4.3.0:1 (anonymous) @ router.js?v=4.4.3.0:1 (anonymous) @ router.js?v=4.4.3.0:1 (anonymous) @ router.js?v=4.4.3.0:1 Promise.then (async) (anonymous) @ router.js?v=4.4.3.0:1 handleRoute @ router.js?v=4.4.3.0:1 page.dispatch @ page.js?v=4.4.3.0:1 page.show @ page.js?v=4.4.3.0:1 page.handleAnchorClick @ page.js?v=4.4.3.0:1 onAnchorClick @ emby-button.js?v=4.4.3.0:1
Happy2Play 9814 Posted August 25, 2020 Posted August 25, 2020 @Smaky @chef @kendoman96 @Spaceboy @Supacat @bugmafia007 @koelner21 Do all of you have the Movie Theme Video plugin installed also?
chef 3811 Posted August 25, 2020 Posted August 25, 2020 57 minutes ago, Happy2Play said: @Smaky @chef @kendoman96 @Spaceboy @Supacat @bugmafia007 @koelner21 Do all of you have the Movie Theme Video plugin installed also? Yes, but I don't use the reports plugin. Let me install it and see what happens.
chef 3811 Posted August 25, 2020 Posted August 25, 2020 (edited) @Happy2Play Okay, the reports plugin.... A couple things Is it on Github? Can I make a pull request? Is this it here: https://github.com/MediaBrowser/EmbyReports If it is then we are still usung JQuery in this one Something is "a-miss" with reports. I can confirm it loads with errors over top the previous viewed page. Edited August 26, 2020 by chef
