fshmngr 0 Posted March 2, 2020 Posted March 2, 2020 (edited) Came back this morning 1.0.38 auto-installed and running perfectly.Mint 19.2 on 4.15.0-54-generic with server 4.3.1 and reports 1.0.38 working as expected.May you live a thousand years. Edited March 2, 2020 by fshmngr
fshmngr 0 Posted March 2, 2020 Posted March 2, 2020 Just FYI, currently all reports export with all columns, regardless of which columns are selected. It's unclear if this is the intended functionality.The UI does make me feel like the report should include only the selected items, but, frankly, I'm just happy to have my data.
neik 874 Posted March 2, 2020 Posted March 2, 2020 Just FYI, currently all reports export with all columns, regardless of which columns are selected. It's unclear if this is the intended functionality. The UI does make me feel like the report should include only the selected items, but, frankly, I'm just happy to have my data. I remember exporting just the selected items, so if it like you describe it's a bug, I guess.
Spaceboy 2573 Posted March 3, 2020 Posted March 3, 2020 Hi, i installed the reports plugin on a stable server and i cannot get the page to render properly here you can see that i've tried to open it from the dashboard and some of the buttons just appear over the top of the open page. works fine on a beta install any update here please or do we just consider this to be broken?
Luke 42255 Posted March 3, 2020 Posted March 3, 2020 I'm looking into it but haven't been able to reproduce yet.
Happy2Play 9814 Posted March 3, 2020 Posted March 3, 2020 As I have mentioned previously on this loading issue, I can only see that page transition for a split second. I caught it refreshing the page several time but for me it always continues to load the Movies page.
Luke 42255 Posted March 3, 2020 Posted March 3, 2020 the good news is that correct me if i'm wrong, but the main lists in the web app have all of the same features except for these two things: configurable fields to show export Is that correct?
Happy2Play 9814 Posted March 3, 2020 Posted March 3, 2020 the good news is that correct me if i'm wrong, but the main lists in the web app have all of the same features except for these two things: configurable fields to show export Is that correct? I believe Missing Episodes also.
Smaky 131 Posted March 17, 2020 Author Posted March 17, 2020 Well for me the loading issue has not gone away in my three servers... PC, Synology NAS and ReadyNAS OS all of them running betas.
Spaceboy 2573 Posted March 17, 2020 Posted March 17, 2020 I’m not sure any effort has been made to fix it
Luke 42255 Posted March 17, 2020 Posted March 17, 2020 I have tried to reproduce but without seeing it happen it's tough to make changes to try and fix it. At this point I'd rather focus on expanding the list features in the core app so that you don't need to use the reports plugin anymore.
Spaceboy 2573 Posted March 17, 2020 Posted March 17, 2020 I have tried to reproduce but without seeing it happen it's tough to make changes to try and fix it. At this point I'd rather focus on expanding the list features in the core app so that you don't need to use the reports plugin anymore. happy to give you temporary admin access to my server if that will help you solve it
Supacat 3 Posted April 10, 2020 Posted April 10, 2020 Running Emby on my Nas and also seeing this issue. Running Emby 4.2.2.0. Tried older version of the plugin and the newest with the same effect. Any update on a fix? Seems to be lots of people with this issue.
Luke 42255 Posted April 10, 2020 Posted April 10, 2020 Seems to be lots of people with this issue. Yes there are, but I'm focusing more of my time on expanding the list features in the server core so that the reports plugin won't be needed anymore. It's not really too far off at this point, mainly the selectable columns and export features. 1
Supacat 3 Posted April 10, 2020 Posted April 10, 2020 Yes there are, but I'm focusing more of my time on expanding the list features in the server core so that the reports plugin won't be needed anymore. It's not really too far off at this point, mainly the selectable columns and export features. Many thanks for the response! Good to hear. Any suggestion until then on how to export your media in a excel or cvs. The statistics plug in look like it has the ability to do this and says it was last run for me today but is showing me an old export from months ago. Thanks for any tips on getting an export of my current collection and thanks for all the work you are doing!
Supacat 3 Posted May 4, 2020 Posted May 4, 2020 Yes there are, but I'm focusing more of my time on expanding the list features in the server core so that the reports plugin won't be needed anymore. It's not really too far off at this point, mainly the selectable columns and export features. Any update on the server core update? Just curious if you need a beta tester for it :-)
Luke 42255 Posted May 4, 2020 Posted May 4, 2020 Any update on the server core update? Just curious if you need a beta tester for it :-) Not yet, sorry.
bugmafia007 12 Posted July 7, 2020 Posted July 7, 2020 Hi, same report issue : any solution for this ? Thanks
bugmafia007 12 Posted July 8, 2020 Posted July 8, 2020 (edited) Hi, When trying to use the report i see only this : any ideas good people ? Edited July 8, 2020 by bugmafia007
ebr 16346 Posted July 8, 2020 Posted July 8, 2020 Probably a theme issue. Try it with the forum default theme. @Abobader
bugmafia007 12 Posted July 8, 2020 Posted July 8, 2020 tried that ..no answer yet ..and there is no special theme ..is the default one that arrives with EMBY installation
Abobader 3485 Posted July 8, 2020 Posted July 8, 2020 @ebr He talking regarding Emby server, not Emby community
Spaceboy 2573 Posted July 8, 2020 Posted July 8, 2020 He’s already reported it in the plugin thread but it had already been reported by others ( including me) some time ago. It has not been looked at though
bugmafia007 12 Posted July 8, 2020 Posted July 8, 2020 (edited) So wait a second @Spaceboy ..so nobody cares about this issue? Edited July 8, 2020 by bugmafia007
