Smaky 131 Posted August 2, 2019 Author Posted August 2, 2019 He is missing a closing div in his markup. Well half-way to getting something fixed is to find the root cause of the issue. Hopefully this might help getting this fixed once and for all.
Luke 42255 Posted August 2, 2019 Posted August 2, 2019 Well half-way to getting something fixed is to find the root cause of the issue. Hopefully this might help getting this fixed once and for all. I think he's commenting about the auto-organize plugin.
Smaky 131 Posted August 2, 2019 Author Posted August 2, 2019 I think he's commenting about the auto-organize plugin. Bummer
Happy2Play 9814 Posted August 2, 2019 Posted August 2, 2019 (edited) I still can't get it to stop on the issue but to be it would appear there is a load order issue somewhere as this appears as the page is transitioning to open for me. Where others are seeing it stop there. So part of the three dot sidebar menu is loading first. But mine loads completely on multiple Windows systems stable and beta (IE, Edge, FireFox,Chrome). Actually looking at the screenshot Albums appear to load first also and transitions to Movies as default landing. Everyone else that sees this issue hangs at this transition. Edited August 2, 2019 by Happy2Play
Luke 42255 Posted August 12, 2019 Posted August 12, 2019 I posted an update to the reports plugin for an unrelated reason but while i was there i didn't see this problem.
shimmerknight 5 Posted August 15, 2019 Posted August 15, 2019 Perhaps the errors that show from Firefox's debugger console may point you in the right direction for a solution. The script from “http://localhost:8096/web/configurationpage?name=reportsjs&v=4.2.1.0” was loaded even though its MIME type (“text/html”) is not a valid JavaScript MIME type. index.html Loading failed for the <script> with source “http://localhost:8096/web/configurationpage?name=reportsjs&v=4.2.1.0”. index.html:1:1 Error: Load failed: configurationpage?name=reportsjs: http://localhost:8096/web/configurationpage?name=reportsjs&v=4.2.1.0 alameda.js:1:10090 RequireJS error: Error: Load failed: configurationpage?name=reportsjs: http://localhost:8096/web/configurationpage?name=reportsjs&v=4.2.1.0. Failed modules: app.js:1:11647
Happy2Play 9814 Posted October 19, 2019 Posted October 19, 2019 Broke in 4.3.0.15. 2019-10-18 19:25:07.391 Error HttpServer: Error processing request *** Error Report *** Version: 4.3.0.15 Command line: Y:\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///Y:/Emby-Server/system/System.Private.CoreLib.dll Processor count: 12 Program data path: Y:\Emby-Server\programdata Application directory: Y:\Emby-Server\system System.MissingMethodException: System.MissingMethodException: Method not found: 'MediaBrowser.Controller.Entities.BaseItem[] MediaBrowser.Controller.Entities.BaseItem.GetDisplayExtras()'. at EmbyReports.Api.Data.ReportBuilder.GetRow(BaseItem item) at EmbyReports.Api.Data.ReportBuilder.GetReportRows(IEnumerable`1 items, List`1 options) at EmbyReports.Api.Data.ReportBuilder.GetResult(BaseItem[] items, IReportsQuery request) at EmbyReports.Api.ReportsService.GetReportResult(GetItemReport request, User user) at EmbyReports.Api.ReportsService.Get(GetItemReport request) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 host, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: EmbyReports TargetSite: EmbyReports.Api.Model.ReportRow GetRow(MediaBrowser.Controller.Entities.BaseItem)
Happy2Play 9814 Posted October 19, 2019 Posted October 19, 2019 1.0.36.0 resolves issue in beta 4.3.0.15.. 1
rbjtech 5345 Posted October 19, 2019 Posted October 19, 2019 How are you getting 1.0.36.0 please - only 1.0.35.0 (Release) is available to download ?
Happy2Play 9814 Posted October 19, 2019 Posted October 19, 2019 (edited) How are you getting 1.0.36.0 please - only 1.0.35.0 (Release) is available to download ? I grabbed it off github and built it when I saw the update. But appears to be available via update and catalog now. Edited October 19, 2019 by Happy2Play 1
rbjtech 5345 Posted October 20, 2019 Posted October 20, 2019 I grabbed it off github and built it when I saw the update. But appears to be available via update and catalog now. Yep there now - Thanks !
kendoman96 2 Posted November 11, 2019 Posted November 11, 2019 (edited) Hey guys, I've been having this issue for a while but never really looked into it. This thread is pretty informative but right now I'm on 4.2.1.0 Archlinux and I have 1.0.36.0 installed. Was there a workaround for this or am I being obtuse? Edited November 11, 2019 by kendoman96
Luke 42255 Posted November 11, 2019 Posted November 11, 2019 I would suggest trying again with the upcoming 4.3 release. Thanks. 1
Spaceboy 2573 Posted February 8, 2020 Posted February 8, 2020 Hi, i installed the reports plugin on a stable server and i cannot get the page to render properly here you can see that i've tried to open it from the dashboard and some of the buttons just appear over the top of the open page. works fine on a beta install
Happy2Play 9814 Posted February 8, 2020 Posted February 8, 2020 @@Spaceboy Merged into existing topic. This issue has affected several users across multiple version. I do not see this on any of my stable or beta servers. 1
Smaky 131 Posted February 12, 2020 Author Posted February 12, 2020 Well for me it never changed.. I am on 4.3.1.0 on Synology and 4.4.0.12 on Windows 10 and ReadyNAS and all of them do not render the interface properly. Reports plugin isntalled... 1.0.36.0
Luke 42255 Posted February 12, 2020 Posted February 12, 2020 That's very strange. Thanks for reporting.
fshmngr 0 Posted March 1, 2020 Posted March 1, 2020 Hello. Thank you, first of all, for all your excellent hard work.I am running Emby Server 4.3.1.0 with Reports 1.0.37.0 on mint with 4.15.0-54-generic Exporting works perfectly, with the exception of any use of "ALL" page length. If I use any preset page length other than "All" it will export perfectly.Any configuration involving "all" fails with "Object reference not set to an instance of an object." Unfortunately, this appears to be making it impossible to effectively export full library.I am relatively new to your software. If you link me to standard methods for retrieving emby logs, I will post them for you. Thanks again. Absolutely beautiful software, all considered.
Luke 42255 Posted March 1, 2020 Posted March 1, 2020 Hello. Thank you, first of all, for all your excellent hard work. I am running Emby Server 4.3.1.0 with Reports 1.0.37.0 on mint with 4.15.0-54-generic Exporting works perfectly, with the exception of any use of "ALL" page length. If I use any preset page length other than "All" it will export perfectly. Any configuration involving "all" fails with "Object reference not set to an instance of an object." Unfortunately, this appears to be making it impossible to effectively export full library. I am relatively new to your software. If you link me to standard methods for retrieving emby logs, I will post them for you. Thanks again. Absolutely beautiful software, all considered. Hi there, can you please attach the emby server log? This sounds vaguely familiar though, it might be resolved for the next release of emby server.
Happy2Play 9814 Posted March 1, 2020 Posted March 1, 2020 (edited) Hello. Thank you, first of all, for all your excellent hard work. I am running Emby Server 4.3.1.0 with Reports 1.0.37.0 on mint with 4.15.0-54-generic Exporting works perfectly, with the exception of any use of "ALL" page length. If I use any preset page length other than "All" it will export perfectly. Any configuration involving "all" fails with "Object reference not set to an instance of an object." Unfortunately, this appears to be making it impossible to effectively export full library. I am relatively new to your software. If you link me to standard methods for retrieving emby logs, I will post them for you. Thanks again. Absolutely beautiful software, all considered. I have no issues with "ALL" on my Windows systems, stable or beta. I guess the question would be is this a OS or Database issue. You will probably need to post a server log showing this error. Edited March 1, 2020 by Happy2Play
fshmngr 0 Posted March 1, 2020 Posted March 1, 2020 (edited) Hi there, can you please attach the emby server log? This sounds vaguely familiar though, it might be resolved for the next release of emby server. embyserver.txt Edited March 1, 2020 by fshmngr
fshmngr 0 Posted March 1, 2020 Posted March 1, 2020 If you become aware of a work-around or system configuration that might fix this prior to the upcoming release, based on the log files, I would love t hear it.Glad to hear its running stable on Windows, I wish I could make the switch. Thanks again!
Happy2Play 9814 Posted March 2, 2020 Posted March 2, 2020 (edited) @@fshmngr Any change in plugin update 1.0.38? add null check This should be the update comment instead of compatibility update. Edited March 2, 2020 by Happy2Play 1
