Luke 42203 Posted September 10, 2020 Posted September 10, 2020 On 9/2/2020 at 9:43 PM, Happy2Play said: I have not figured it out exactly but I get the same result with tracks without Musicbrainz ids embedded. My guess would be the by name lookup is creating issues for ACE and ACE+. As mentioned above using Picard provided correct results. But will be doing some more testing. @Luke does that sound right? Yes that is exactly right.
Solution Eradev 8 Posted May 22, 2021 Author Solution Posted May 22, 2021 Seems to be corrected in the latest version.
