bmgsackboy 0 Posted August 22, 2020 Posted August 22, 2020 Hey so I'm having a issue with new content that has been added. EMBY is no longer showing the actor role automatically when downloading or refreshing metadata, old content has not been affected only new content that's been added I've attached some photos showing the issue I can attach a log file if needed. Thanks
pünktchen 1410 Posted August 22, 2020 Posted August 22, 2020 Change TMDB back to number one in your prefered metadata provider order of your libraries. 1
Happy2Play 9802 Posted August 22, 2020 Posted August 22, 2020 (edited) What is your metadata downloader order? I will guess OMDB, then TMDB. OMDB does not contain a Role only by name. Technically this was a change to be able to get actors listed in OMDB metadata. So we see these side effects seen in attached topic. All already processed items would have to be Refreshed once you change the provider order. Edited August 22, 2020 by Happy2Play
bmgsackboy 0 Posted August 23, 2020 Author Posted August 23, 2020 1 hour ago, pünktchen said: Change TMDB back to number one in your prefered metadata provider order of your libraries. TMDB is the main metadata supplier i haven't changed any settings since my initial set up which would have been a few years ago, this issue is a recent issue as new media isn't being added properly in my attached photos the added media date is about a month apart between the "old" and "new" media.
bmgsackboy 0 Posted August 23, 2020 Author Posted August 23, 2020 This is the current library settings. 1 hour ago, Happy2Play said: What is your metadata downloader order? I will guess OMDB, then TMDB. OMDB does not contain a Role only by name. Technically this was a change to be able to get actors listed in OMDB metadata. So we see these side effects seen in attached topic. All already processed items would have to be Refreshed once you change the provider order. TMDB is the main supplier.
Happy2Play 9802 Posted August 23, 2020 Posted August 23, 2020 1 minute ago, bmgsackboy said: This is the current library settings. TMDB is the main supplier. What server and TMDB/OMDB plugin versions? Does metadata comes from Emby? If you Refreshed the item does it get the Role?
Happy2Play 9802 Posted August 23, 2020 Posted August 23, 2020 Actually looking at the Overview of Ransom the information came from OMDB. So my guess would be your connection to TMDB api failed. Only way to verify this would be to look for errors in your server log. OMDB snipped Quote ,"Director":"Ron Howard","Writer":"Cyril Hume (story), Richard Maibaum (story), Richard Price (screenplay), Alexander Ignon (screenplay)","Actors":"Mel Gibson, Rene Russo, Brawley Nolte, Gary Sinise","Plot":"Multimillionaire Tom Mullen decides to take matters into his own hands after his beloved son is kidnapped." TMDB snipped Quote "overview":"When a rich man's son is kidnapped, he cooperates with the police at first but then tries a unique tactic against the criminals."
bmgsackboy 0 Posted August 23, 2020 Author Posted August 23, 2020 1 hour ago, Happy2Play said: Actually looking at the Overview of Ransom the information came from OMDB. So my guess would be your connection to TMDB api failed. Only way to verify this would be to look for errors in your server log. OMDB snipped TMDB snipped Thank you i took a look at the logs and it had failed several times, might have to look into why now thanks for the help.
bmgsackboy 0 Posted August 25, 2020 Author Posted August 25, 2020 On 22/08/2020 at 20:17, Luke said: What was the error message? if im looking at this correct, under the Error report section in the logs says error code is 111, it is working now i noticed that it had several failed connections to open subs as well, i was having some network and switch issues which i believe was causing timeout error for embys connections, it had also failed creating a port map multiple times so honestly no clue if it was something within embys config, or my router switch issue.
Happy2Play 9802 Posted August 25, 2020 Posted August 25, 2020 (edited) 1 hour ago, bmgsackboy said: it had also failed creating a port map multiple times OT: Honestly unless you know you use port mapping/UPNP I would disable it. Edited August 25, 2020 by Happy2Play
bmgsackboy 0 Posted August 25, 2020 Author Posted August 25, 2020 11 hours ago, Happy2Play said: OT: Honestly unless you know you use port mapping/UPNP I would disable it. Thanks I did, I definitely don't need that on I think i might have accidentally tapped it in the mobile app when scrolling through settings.
bmgsackboy 0 Posted August 25, 2020 Author Posted August 25, 2020 11 hours ago, Luke said: Thanks for the feedback. No worries thanks for the quick helps guys, idk how to mark unrelated/solved
