pix64 2 Posted April 26, 2024 Posted April 26, 2024 @chacawacaor @vdrover Is it possible to use this awesome docker to only generate the EDL file and not do the file conversion? I don't mind there being the .ts files for recordings, but really don't want to remux or convert the file into something else. If this is possible, could you please point me in the right direction on how I might accomplish that? Thanks!
chacawaca 109 Posted April 27, 2024 Author Posted April 27, 2024 No, your better with a comskip docker only then. Comskip will generate .edl and do nothing else to your file.
BenVenn 22 Posted May 15, 2024 Posted May 15, 2024 I spent a bit of time troubleshooting this on my Synology DS2422+ today and eventually got FFMPEG to actually process my .ts files after amending my custom.sh as below. Posting in case it helps anyone else. It's running an AMD CPU, although I'm not sure if that was the cause or not. I'm very new to this so had to piece it together as I went along. ffmpeg -i "$INPUT" -hide_banner -loglevel info -max_muxing_queue_size 512 -c:v libx265 -brand mp42 -ac 2 -c:a libfdk_aac -b:a 128k -ignore_unknown -map 0:v -map 0:a:0 "$OUTPUT" -probesize 100M -analyzeduration 100M ffmpeg -i "$INPUT" -hide_banner -loglevel info -max_muxing_queue_size 512 -c:v libx265 -brand mp42 -ac 2 -c:a libfdk_aac -b:a 128k -ignore_unknown -map 0:v -map 0:a:0 "$OUTPUT" -probesize 100M -analyzeduration 100M 1
abescalamis 88 Posted August 27, 2024 Posted August 27, 2024 (edited) On 4/27/2024 at 6:39 AM, chacawaca said: No, your better with a comskip docker only then. Comskip will generate .edl and do nothing else to your file. Hello, wanted to know if you know of a good comskip docker only, the very few I found have no documentation about how to use. Edited August 27, 2024 by abescalamis
abescalamis 88 Posted February 26 Posted February 26 On 4/26/2024 at 12:49 PM, pix64 said: @chacawacaor @vdrover Is it possible to use this awesome docker to only generate the EDL file and not do the file conversion? I don't mind there being the .ts files for recordings, but really don't want to remux or convert the file into something else. If this is possible, could you please point me in the right direction on how I might accomplish that? Thanks! On 4/27/2024 at 6:39 AM, chacawaca said: No, your better with a comskip docker only then. Comskip will generate .edl and do nothing else to your file. Hi, I manage to set to remux the .ts to .MKV it takes 46s for a 1hr show, and adds the EDL and chapters to the video, total time 2:30 minutes per video, if I disable generating chapters it takes 1minute and few seconds. Thank you. the container is awesome, it was a bit tricky to set just to remux. 1
