Twixter 4 Posted August 20, 2020 Posted August 20, 2020 Hello, I have a small issue, i have a folder with 6000 files that all need to be renamed. The good news is i need to remove the exact same part. The structure of the files is that they are numbered before the file part it's numbered from 0001 to 6000 So for example 0003 - Filename 0139 - Filename 4239 - Filename So i need to remove XXXX - From all 6000 files (the numbers and the - ) and i don't feel like doing that by hand. Could anyone suggest me a easy way to rename all of this at once?
arrbee99 1836 Posted August 20, 2020 Posted August 20, 2020 Bulk Rename Utility has a remove first x characters, if thats what you want (and a Preview to check its going to do it correctly). 2
Twixter 4 Posted August 20, 2020 Author Posted August 20, 2020 I've looked over the interface but it looked very intimidating . Could you maybe point me in the right direction? as long as i can preview it there is no risk + i made a copy of the folder just incase
Twixter 4 Posted August 20, 2020 Author Posted August 20, 2020 I just noticed the remove first/from part i just need the preview now.
arrbee99 1836 Posted August 20, 2020 Posted August 20, 2020 Guess you'd just put a 6 or whatever for First n and leave From as is. Remember to count spaces.
Gilgamesh_48 1243 Posted August 20, 2020 Posted August 20, 2020 For simple renaming jobs I use the lite version of The ReNamer 2
Twixter 4 Posted August 20, 2020 Author Posted August 20, 2020 Thanks a lot for the fast responses! I'm gonna try it out.
Twixter 4 Posted August 20, 2020 Author Posted August 20, 2020 Renamed everything successfully, thanks everyone for the help! 1
Carlo 4561 Posted August 20, 2020 Posted August 20, 2020 Glad you got it worked out Twixter. I could have thrown a little script together for you but this is better. LOL.
Twixter 4 Posted August 20, 2020 Author Posted August 20, 2020 Yeah i've been wanting to get into scripting myself but i've never really taken the time for it but it can safe you SO much time in the long run and it's so versatile. 1
