smills 13 Posted August 19, 2020 Posted August 19, 2020 I would be nice if when you added a Live TV Source you could edit a descriptive and unique name instead of all M3U Tuners just showing as "M3U Tuner". Today when I was testing locast2plex would be nice if I could name that Source "locast2plex" rather than having it simply show as a HD Homerun. Would be nice if there was a way to mark a tuner as disabled rather than simply deleting it. I was testing the locast2plex today and wanted to get rid of my other tuners to insure I was watching the Locast streams and I had to go delete them and then of course later had to re-add then and redo my channel mappings. Sure would have saved me a bunch of time if there was a simple checkbox to just disable/enable a source. Regards, 2
smills 13 Posted August 19, 2020 Author Posted August 19, 2020 @ebr I think that other thread you link and what @BobbyDing is asking for is different. What I am asking for is a way to enable to disable a source with a checkbox so that it would nto appear i tnhe guide and not be used but would stay configured. What Bobby wants to do is setup a HDHomerun source and limit the maximum number of streams that Emby will try to use from it. For me I have my HDHomerun Quattro but I have no way to tell Emby how many of the 4 tuners in that device t try and use. . But for an M3U tuner I CAN indicate how many simultaneous streams to attempt from that source. It seems to me if a similar setting was available for HD Homerun tuners then that would meet Bobby's requirement as that would effectively limit the number of "tuners " to be used from that "Source". It seems like a possible solution for Bobby might be to setup his HDHR as a M3U source rather than a HDHR native source. I tried it real quick and it seemed to work fine. . Regards
smills 13 Posted August 19, 2020 Author Posted August 19, 2020 Want to be clear what I was asking for in my feature request. I wanted to be able Edit the source and specify a Friendly Name so that all the numbers of a type didn't look identical. And then if the was a way to click the ... and get a menu choice to Enable or Disable the source (or even a checkbox on the edit details pagelet) so that I can disable a source but leave it configured so that it can be quickly re enabled later without having to remap my guide data and setup my icons again.
smills 13 Posted August 20, 2020 Author Posted August 20, 2020 @cayars, I realize what we see is the tuner type and that is sort of precisely my point. All tuners of a single type are looking identical. Would be nice to be able to Assign a Friendly name to them 1
ebr 16339 Posted August 20, 2020 Posted August 20, 2020 15 hours ago, smills said: @ebr I think that other thread you link and what @BobbyDing is asking for is different. If his request were implemented (the ability to disable individual tuners in a device) then, by disabling all tuners on a device, you could do exactly what you asked for as your second request. BTW - please create individual feature requests as it is impossible to track when there are multiples in a single topic. You don't need to do that this time because your second request already exists. Thanks!
