mbc0 68 Posted August 18, 2020 Posted August 18, 2020 (edited) Hi, I have some very very large libraries in Movies/TV/Music and after a glitch where Emby suddenly could not see any of my media (do not know why) I restarted the Emby container and now all my media is missing it's artwork so I have changed the library settings to store artwork in the media folders but would like to know how I can clean up the (presumably still existing) artwork from my cache drive? Thank you Edited August 19, 2020 by mbc0
mbc0 68 Posted August 21, 2020 Author Posted August 21, 2020 Is there an explanation of the emby directory structure so I can work out what directories I can delete? searching only shows up naming structures.. I have 70GB of metadata on my emby installation I would like to clean up.
Happy2Play 9802 Posted August 21, 2020 Posted August 21, 2020 You could do a blank explorer search for backdrop or clearlogo or discart or landscape or poster (pretty sure all people/artist are folder.ext) You would search your /metadata/library folder. The grey area is older databases are still linked to the old /metadata/people folder and genre folder, but new ones are not.
mbc0 68 Posted August 21, 2020 Author Posted August 21, 2020 Many Thanks @Happy2Play it could take a while but thanks!
