daffyonlsd 0 Posted August 17, 2020 Posted August 17, 2020 Im just wondering when I set tuner(m3u) "simultaneous stream limit: 2" should that not hide the channels for that tuner when that limit is reached? At the moment it does not... thanks Linux / emby 4.3.3.0
Luke 42244 Posted August 17, 2020 Posted August 17, 2020 Hi, no, it will show them and then give an error message when they try to play.
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 3 hours ago, daffyonlsd said: Im just wondering when I set tuner(m3u) "simultaneous stream limit: 2" should that not hide the channels for that tuner when that limit is reached? At the moment it does not... thanks Hello daffyonlsd, You really wouldn't want the channels to disappear. How would you look through the EPG to pick things to record later if the channels weren't there?
daffyonlsd 0 Posted August 17, 2020 Author Posted August 17, 2020 2 hours ago, cayars said: Hello daffyonlsd, You really wouldn't want the channels to disappear. How would you look through the EPG to pick things to record later if the channels weren't there? I guess you're right, just shows how much the feature to select specific tuner for specific user is needed really.
