David Patt 21 Posted August 17, 2020 Posted August 17, 2020 Hello , i am using server on my pc so i turn it off at the end of the day. When i turn pc on and server on sometimes this happens. I use library in this style ANIME/A/Accel world , ANIME/B/Banana Fish. etcc.. Every alphabet folder has his custom image. But sometimes image dissapear and there is random image from its subfolder. I fix it and then after few restarts it is corrupt again. Can i prevent it to happen ? Thank you. (Dont mind two D , i start correct it and i make mistake)
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 Hello David, Can you tell us what version of the Server you are running?
ebr 16310 Posted August 17, 2020 Posted August 17, 2020 Hi. Do the ones that show a single image have just one video item under them?
David Patt 21 Posted August 17, 2020 Author Posted August 17, 2020 57 minutes ago, cayars said: Hello David, Can you tell us what version of the Server you are running? Latest stable 4.4.3.0 44 minutes ago, ebr said: Hi. Do the ones that show a single image have just one video item under them? No each folder with letter contain multiple anime series and movies. It just randomly change image from letter image I set up to one of the subfolders anime series or movie poster (mostly first )
Happy2Play 9802 Posted August 17, 2020 Posted August 17, 2020 Does the folders actually contain the applied image? Might be a save to folder issue. 1
David Patt 21 Posted August 17, 2020 Author Posted August 17, 2020 (edited) On 8/17/2020 at 4:59 PM, Happy2Play said: Does the folders actually contain the applied image? Might be a save to folder issue. I will try it. Thank you for suggestions. Edit: Looks like that make it. Edited August 18, 2020 by David Patt
