lastelement21 17 Posted August 17, 2020 Posted August 17, 2020 Hi! I am successfully using the /Sessions/{id}/Playing and /Sessions/{id}/Playing/{Command} api endpoints to control the web player and the Android app sessions, but I am having no luck with the Chromecast sessions. Does the chromecast app not support these? I'm making sure the app is running, and I'm getting a 204 back from the endpoint, same as with the other clients, but nothing happens. Thanks
Solution Luke 42210 Posted August 25, 2020 Solution Posted August 25, 2020 Hi, that's correct, it's not supported. There is no direct line of communication from server to chromecast receiver.
