DarkKniyt (John) 6 Posted August 16, 2020 Posted August 16, 2020 Started having issues with getting TMDB data. Specifically, Actor Images. I'm attaching my log file which shows time-out errors. Any help would be greatly appreciated! embyserver.txt
Luke 42210 Posted August 16, 2020 Posted August 16, 2020 Hi, a time out error means either moviedb was down at the time or you had some kind of connection problem. I would give it a try again later.
Happy2Play 9802 Posted August 16, 2020 Posted August 16, 2020 Sorry the attached log is empty. Could you attach another server log.
DarkKniyt (John) 6 Posted August 17, 2020 Author Posted August 17, 2020 Luke, Have tried numerous times over a number of days with no luck. Happy Trying the Log again. Also, here's the part of the log with the error; 2020-08-16 17:42:52.976 Error App: Error in TheMovieDb *** Error Report *** Version: 4.4.3.0 Command line: C:\Users\JNDSERVER\AppData\Roaming\Emby-Server\system\EmbyServer.dll Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/JNDSERVER/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.4 Processor count: 12 Program data path: C:\Users\JNDSERVER\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\JNDSERVER\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Cancelling connection to https://api.themoviedb.org/3/movie/11026?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null due to a previous timeout. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at MovieDb.MovieDbProvider.GetMovieDbResponse(HttpRequestOptions options) at MovieDb.MovieDbProvider.FetchMainResult(String id, Boolean isTmdbId, String language, String country, CancellationToken cancellationToken) at MovieDb.MovieDbProvider.DownloadMovieInfo(String id, String preferredMetadataLanguage, String preferredMetadataCountry, CancellationToken cancellationToken) at MovieDb.GenericMovieDbInfo`1.FetchMovieData(String tmdbId, String imdbId, String language, String preferredCountryCode, CancellationToken cancellationToken) at MovieDb.GenericMovieDbInfo`1.GetMetadata(ItemLookupInfo itemId, CancellationToken cancellationToken) at MediaBrowser.Providers.Manager.MetadataService`2.ExecuteRemoteProviders(MetadataResult`1 temp, String logName, TIdType id, IEnumerable`1 providers, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() embyserver.txt
Luke 42210 Posted August 17, 2020 Posted August 17, 2020 The server is unable to make any outgoing communications, and it's not only to MovieDb but all other domains as well such as OpenSubtitles. This means you have something blocking the server from doing this. The most common causes are usually firewall, security software or VPN. Can you look into that?
DarkKniyt (John) 6 Posted August 17, 2020 Author Posted August 17, 2020 Luke, No go on this. I checked my firewall and all looks correct so I shut it down, restarted Emby and tried again. Getting the same error. I went ahead and attached the new log file. embyserver.txt
Luke 42210 Posted August 17, 2020 Posted August 17, 2020 The log still shows the same thing. Something is blocking the server from sending outgoing requests. You could also try turning off ipv6 in your router. Occasionally that causes an issue. 1
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 Hey John, can you try something for me? Open a browser on your windows server and go here: https://api.themoviedb.org/3/movie/11026?api_key=f6bd687ffa63cd282b6ff2c6877f2669&append_to_response=casts,releases,images,keywords,trailers&language=en&include_image_language=en,null What do you get?
DarkKniyt (John) 6 Posted August 17, 2020 Author Posted August 17, 2020 cayars, I'm getting a bunch of text. Here's a copy of it in a text file. New Text Document.txt
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 OK that looks good. That was the same link from the log earlier where the connect was timed out. Are you absolutely positive there is no vpn or proxy on your network?
DarkKniyt (John) 6 Posted August 17, 2020 Author Posted August 17, 2020 Well... This is weird. After rechecking everything and IPV6, still wouldn't work. Just for kicks I rebooted my router and waalaa - it's working now. I appreciate the help everyone and the quick responses! John.
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 Hehe, so a good kick in the router fixed it up. Glad you got it working!
Solution DarkKniyt (John) 6 Posted August 17, 2020 Author Solution Posted August 17, 2020 Well - I was wrong! I was able to refresh one movie and thought I had all the images and data but turns out I was wrong. BUT - I went into my Ethernet settings and IPV6 was checked. Unchecked it. Now everything is downloading correctly? Luke - any explanation for this?
DarkKniyt (John) 6 Posted August 17, 2020 Author Posted August 17, 2020 No problem Luke. At least it's working now. I would never had thought about IPv6!
