slyfox 48 Posted August 16, 2020 Posted August 16, 2020 (edited) I am in a process of moving my libraries from NAS to Mac mini. I have about 25 libraries and it is a pain in the *** to update the location of each library. Can you please add a simple way to bulk edit libraries to update locations? Edited August 16, 2020 by slyfox
ebr 16337 Posted August 16, 2020 Posted August 16, 2020 Hi. How would you envision this working such that it would be quicker? Thanks.
slyfox 48 Posted August 16, 2020 Author Posted August 16, 2020 Settings - Library - Advanced - Edit Libraries Location Plain Text Entires - Each library on its own line. Copy and paste to TextEdit - Find and Replace entires Paste back into Emby. Click save and rescan.
Happy2Play 9812 Posted August 16, 2020 Posted August 16, 2020 And that would update every item in the database some how? You can technically do this all manually off line by updating library paths in /root/default and updating the database manually
slyfox 48 Posted August 16, 2020 Author Posted August 16, 2020 1 minute ago, Happy2Play said: And that would update every item in the database some how? You can technically do this all manually off line by updating library paths in /root/default and updating the database manually No, in the scenario that I proposed, clicking save would trigger library update. Can you please provide more details on "/root/default" where would this be found on a Mac?
Happy2Play 9812 Posted August 16, 2020 Posted August 16, 2020 2 minutes ago, slyfox said: Can you please provide more details on "/root/default" where would this be found on a Mac? It is in the Emby programdata folder. You should see the general path via the Dashboard Paths box or in the to section of a log. But updating the the <PathInfos> in the libraries option.xml still requires manual update in the database or all items will be purged do to database containing a item with a old path that does not exist any more. Discussion here, not a simple task
Nzzer0 7 Posted December 11, 2024 Posted December 11, 2024 i too would love to be able to edit a simple text file to update all server paths ... i have 100 libraries to update the paths for since i moved it off my synology and it would be so easy to search and replce but instead Im lookling at hours and hours of repeating the same task to change the same path in each library. And the above instructions make absolutely no sense, sorry. 1
Happy2Play 9812 Posted December 11, 2024 Posted December 11, 2024 (edited) 7 hours ago, Nzzer0 said: i too would love to be able to edit a simple text file to update all server paths ... i have 100 libraries to update the paths for since i moved it off my synology and it would be so easy to search and replce but instead Im lookling at hours and hours of repeating the same task to change the same path in each library. And the above instructions make absolutely no sense, sorry. Have had hit and miss results as I assume not every area gets properly updated and will guess there may be even more locations that may need updates. But I had no issues with a basic move not to long ago. Manual library.db update UPDATE "main"."MediaItems" SET "Path" = replace( "Path", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE path LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."MediaItems" SET "Images" = replace( "Images", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE Images LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."MediaStreams2" SET "Path" = replace( "Path", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE path LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."Chapters3" SET "ImagePath" = replace( "ImagePath", 'C:\Users\Media\Desktop\Videos', 'E:\Media' ) WHERE imagepath LIKE 'C:\Users\Media\Desktop\Videos%'; UPDATE "main"."ItemExtradata" SET "Value" = replace( "Value", '"Path":"C:\\Users\\Media\\Desktop\\Videos', '"Path":"E:\\Media' ) WHERE value LIKE '%"Path":"C:\\Users\\Media\\Desktop\\Videos%'; If you filled in Network path on Library setup you will could need to update in options.xml and itemextradata. xml is obsolete in new 4.8+ Cinema Intro plugin paths If you use AutoOrganizer you will need to update or delete the fileorganization.db If you applied user images then path will need updated users.db Edited December 11, 2024 by Happy2Play
