maxsteel85 0 Posted August 15, 2020 Posted August 15, 2020 Having issue with filtering inside the library. For example, I can filter the genre but not any other parameters with it like content rating. Anyone experience the same?
ebr 16338 Posted August 15, 2020 Posted August 15, 2020 Hi. Can you please explain exactly what you are doing and what is happening? Thanks.
maxsteel85 0 Posted August 15, 2020 Author Posted August 15, 2020 8 minutes ago, ebr said: Hi. Can you please explain exactly what you are doing and what is happening? Thanks. well... first, it is working fine on other devices, the issue is only on Shield TV. In movies library, I set the filtering to show documentary films with PG-13 rating. It works only on one part showing documentary films but the rating parameter is not reflected. It shows all different ratings. And that's for all different libraries and genres. Hope that explains it.
ebr 16338 Posted August 15, 2020 Posted August 15, 2020 Hi. Can you show us exactly where you are doing this? Some screen shots would really help. Thanks.
maxsteel85 0 Posted August 15, 2020 Author Posted August 15, 2020 2 minutes ago, ebr said: Hi. Can you show us exactly where you are doing this? Some screen shots would really help. Thanks. I don't think it needs screenshots and unfortunately can't do that form TV. Isn't it clear as I explained it previously?
ebr 16338 Posted August 15, 2020 Posted August 15, 2020 It just helps us confirm exactly where you are and what you are doing. But, is it specifically the parental rating filter that isn't working? If you just filter by rating, does that work?
maxsteel85 0 Posted August 15, 2020 Author Posted August 15, 2020 6 minutes ago, ebr said: It just helps us confirm exactly where you are and what you are doing. But, is it specifically the parental rating filter that isn't working? If you just filter by rating, does that work? No it doesn't work by itself too.
ebr 16338 Posted August 15, 2020 Posted August 15, 2020 Okay, we'll look into that one. Thanks for reporting. Do all the others appear to work?
ebr 16338 Posted August 15, 2020 Posted August 15, 2020 Thanks. I think I've found the issue with the ratings. There was a server change the app wasn't aware of so it needs to adjust. Thanks again for reporting. Without folks like you doing that, we sometimes don't know about these for a long time.
maxsteel85 0 Posted August 15, 2020 Author Posted August 15, 2020 No problem. Sure needs an update to fix right?
ebr 16338 Posted August 15, 2020 Posted August 15, 2020 Just now, maxsteel85 said: No problem. Sure needs an update to fix right? Correct.
