Carlo 4561 Posted August 20, 2020 Posted August 20, 2020 Have you tried resetting the HDHomeRuns? Pull power for 10 seconds then plug back in type thing. You should then be able to access them again from the Emby Server machine. Try that a let us know how it works. If you still can't access them from your server machine try removing IP6 from the LAN adapter and see if that helps.
lklein 2 Posted August 20, 2020 Author Posted August 20, 2020 (edited) Well it's working now. I reset the tuners but that didn't fix it. I disabled IPV6 on the Shield and reset the Emby server on the Shield. I stopped it and ran it again. That seemed to have fix it. If it is Ipv6 then I wonder what's up with that? We might not have Ipv4 after a few years. Thanks for your help. Edited August 20, 2020 by lklein
Carlo 4561 Posted August 20, 2020 Posted August 20, 2020 It's a glitch in the HDHomeRun tuners from what I've seen and reported. They don't respond correctly in IP6 environments. Most likely you got an OS upgrade DLL or something that changed the priority of IP6 over IP4 so your computer tried using IP6 first to communicate and it's hitting the issue.
