lklein 2 Posted August 14, 2020 Posted August 14, 2020 Emby won't show the channel guide anymore. Won't work with emby or schedule direct. Just stop showing the guide a few days ago. No guide or Programs. It just shows the channel icons I thought that Emby would fix this bug by now. What do I do? Thanks Bert
Luke 42242 Posted August 14, 2020 Posted August 14, 2020 Hi there, please try refreshing the guide data in Emby Server and see if this helps. Thanks.
lklein 2 Posted August 14, 2020 Author Posted August 14, 2020 I've done that several times and just did it again now with the same results.
Luke 42242 Posted August 14, 2020 Posted August 14, 2020 How did you import live tv into Emby, with an HD Homerun?
lklein 2 Posted August 14, 2020 Author Posted August 14, 2020 (edited) Yes. I have a dual a connect and a quad connect. The HDHR view program is working okay with them. I see the channels listed in the Emby live TV setup in the channel map. The guide info just doesn't show up. Neither does the program channels. It just shows the channel icons as below. Edited August 14, 2020 by lklein image
Luke 42242 Posted August 14, 2020 Posted August 14, 2020 Can you please run the refresh guide scheduled task and then attach the emby server log after it completes? Thanks.
lklein 2 Posted August 14, 2020 Author Posted August 14, 2020 (edited) Emby Server is on a Shield TV. I'm not sure how to access the log file on it. Not as straight forward as a PC. Edited August 14, 2020 by lklein
Luke 42242 Posted August 14, 2020 Posted August 14, 2020 4 minutes ago, lklein said: Emby Server is on a Shield TV. I'm not sure how to access the log file on it. Not as straight forward as a PC. From the main server admin menu, simply go to the Logs section and you can download log files from there.
Luke 42242 Posted August 15, 2020 Posted August 15, 2020 Attempts to connect to your HD Homerun tuner are timing out and failing: Connection to http://192.168.10.106/discover.json timed out Is your tuner offline? Try rebooting it and then refresh the guide data in emby server again.
lklein 2 Posted August 15, 2020 Author Posted August 15, 2020 My tuners are online. I can watch TV on hdhomerun view, scan channels etc. I deleted all the tuners from Emby and reinstalled them to no avail. Puzzling. Emby's been working great for a month or two. Don't know why Emby log file say's it can't connect or is timing out.
Luke 42242 Posted August 15, 2020 Posted August 15, 2020 Is that the correct ip address for your tuner?
lklein 2 Posted August 15, 2020 Author Posted August 15, 2020 If you sent an image it didn't show up correctly. Just a small box with some gray symbol inside.
Luke 42242 Posted August 15, 2020 Posted August 15, 2020 Is this your tuner ip address? http://192.168.10.106/discover.json
lklein 2 Posted August 15, 2020 Author Posted August 15, 2020 No. That was my old router. I switch to a new one a few days ago.b Here are the ip's of my three hdhomeruns 192.168.0.4. 192.168.0.16 192.168.0.6
Luke 42242 Posted August 15, 2020 Posted August 15, 2020 Ok so then i would go into your server live tv settings, update the ip address of the hd homerun tuner(s), and then refresh the guide data again.
lklein 2 Posted August 15, 2020 Author Posted August 15, 2020 They already have the correct ip numbers since I deleted and added the tuners. I can update the ip numbers but I will just be typing back in the same numbers. Will try anyhow. I appreciate all of your help and sure it will get fix.
lklein 2 Posted August 15, 2020 Author Posted August 15, 2020 Wow that was weird. I actually deleted the ip addresses and type the exact ones back in and it works. I have to remember this. Why I have no idea. Thanks.
Luke 42242 Posted August 16, 2020 Posted August 16, 2020 How could it be the same number when you said earlier that http://192.168.10.106 was not correct?
lklein 2 Posted August 16, 2020 Author Posted August 16, 2020 That number is not correct. It is 192.168.1.4 and the others are the same but instead of ending with 4 they are 16 and 6 like I posted above. Actually you asked me if it was that number and I said no in the post above. I think you probably seen that number in the Emby log text I sent you. That was the number several days back with my old router. I installed another router with the current ip numbers. Somehow Emby show the current ip numbers but it didn't work. I did what you said anyhow and just retyped the same ip numbers that were showing and for some reason it worked.
Carlo 4561 Posted August 17, 2020 Posted August 17, 2020 lklein, Thanks for the update and glad you got it working!
lklein 2 Posted August 19, 2020 Author Posted August 19, 2020 Today started ding it again. I will try the things I did before again. I need a break first though.
lklein 2 Posted August 20, 2020 Author Posted August 20, 2020 Still don't have it working. I deleted my tuners in Emby and reinstalled them. No go. Then I looked at the ips in my router. They were the same as Emby shows. Then I entered the ips by hand. This worked last time but not this time. Everything else works okay with my HDhomeruns. I don't think Emby had any updates lately so it's confusing. The only thing I can think of is I had to have the cable company send a signal to my modem a few times to get the internet working okay. Not sure if that could effect Emby.
