Desert-Rat 5 Posted August 13, 2020 Posted August 13, 2020 Emby is far better, in every way, than Plex. An improvement would be a drop down option from the Menu bar to Scan the Library (videos added to my source folder for the library don't automatically appear in Emby, so I have to scan to load them). 1
Happy2Play 9814 Posted August 14, 2020 Posted August 14, 2020 Sorry I don't follow as there is already a Scan the library on all Libraries menu options (three dot/right click).
Desert-Rat 5 Posted August 14, 2020 Author Posted August 14, 2020 I know, but I thought it would be faster/easier if the Scan option was in the Drop Down from the Menu Bar (it is in Plex - but that's about the only thing I liked better about Plex.)
Happy2Play 9814 Posted August 14, 2020 Posted August 14, 2020 38 minutes ago, Desert-Rat said: I know, but I thought it would be faster/easier if the Scan option was in the Drop Down from the Menu Bar (it is in Plex - but that's about the only thing I liked better about Plex.) As a non-Plex user, where are you calling the Menu bar? To me I don't know what would be faster as I don't know the context of where you are referring to. But would it not be two clicks no matter what?
Desert-Rat 5 Posted August 14, 2020 Author Posted August 14, 2020 I'm using a Mac Mini, with Catalina. I've attached a screenshot of where I''m referring to.
Happy2Play 9814 Posted August 14, 2020 Posted August 14, 2020 (edited) So you are suggesting Scan Library files via the Tray icon. Will have to look but pretty sure there are other FRs. Edited August 14, 2020 by Happy2Play
Desert-Rat 5 Posted August 14, 2020 Author Posted August 14, 2020 In the grand scheme of things, Emby is terrific; my suggestion was just a leftover from Plex (one of its features.). What's "FRs"?
Happy2Play 9814 Posted August 14, 2020 Posted August 14, 2020 2 minutes ago, Desert-Rat said: What's "FRs"? This forum section "Feature Requests"
Desert-Rat 5 Posted August 14, 2020 Author Posted August 14, 2020 Ah hah! Thank you...Isn't that where I posted; isn't this the the FR section? I looks like I've mis-posted...Please tell me where to go (it won't be the first time I've been told where to go). Thanx for your help, Michael
Happy2Play 9814 Posted August 14, 2020 Posted August 14, 2020 4 minutes ago, Desert-Rat said: Ah hah! Thank you...Isn't that where I posted; isn't this the the FR section? I looks like I've mis-posted...Please tell me where to go (it won't be the first time I've been told where to go). Thanx for your help, Michael Your in the right place, just thought this was requested before but may have been in a normal topic.
Desert-Rat 5 Posted August 14, 2020 Author Posted August 14, 2020 I tried to find a similar post, but I didn't see one. Thanx for putting up with me. Michael
