anoyeduser 0 Posted August 13, 2020 Posted August 13, 2020 (edited) I just installed Kodi and Embycon for my jellyfin server and I've been having some issues: 1. Starting a show in kodi immediately marks it unwatched on my server (a major issue for obvious reasons) - I saw something on the forums about it being a possibility that the trakt.tv plugin can cause these issues, but it was not the case. 2. I have issues with the default clone of the Estuary skin because of mouse support, are there skins with good mouse support (meaning that I can do things like seek based off the bar and drag it, like in any other media player, and scroll in context menus [like those found describing plugins]) that work well with embycon? If not for these 2 issues, my setup would finally "work properly" in my eyes, so I really want to fix them so I can put my family on the server, any help is appreciated. Edited August 13, 2020 by anoyeduser
TeamB 2440 Posted August 13, 2020 Posted August 13, 2020 jellyfin? You might need to try their Reddit sub : https://www.reddit.com/r/jellyfin/
anoyeduser 0 Posted August 14, 2020 Author Posted August 14, 2020 Issue #1 is most likely behavior of embycon and kodi (jellyfin is similar enough to emby that it works the same) also as for issue #2, has literally nothing to do with jellyfin...... did you read past the first sentance?
TeamB 2440 Posted August 14, 2020 Posted August 14, 2020 yes I did read past the first sentence, I read it all, #2 is a Kodi skin problem/limitation, not my area of main interest or experience so someone else can perhaps answer that for you. Is that ok?
