andrew0404 13 Posted August 13, 2020 Posted August 13, 2020 I stopped using AutoBoxSets recently because I was tired of it automatically deleting my custom collections. I thought I would run it once, remove it and then add my collections. I couldn't figure out why seeming randomly It would decide to remove my collections. I think I figured out what was happening. I have a (separate) issue where occasionally a drive will become unresponsive. If I don't catch it in time, Emby will start removing the movies from that drive from the db. That makes sense and is easy to correct by rescanning the library once I get the drive back online. Unfortunately, each of those removed movies are now not in any collection, leaving me combing through my entire library to manually place them. I guess at this point AutoBoxsets is better than nothing. 90% of my collections can be managed by autoboxsets, I just wish there was a way that I could have it leave my custom collections alone. Or even better, if there was a way to have these movies pop back into their collections when they are rescanned. I realized while typing this that all that is probably in the db, and there is probably no way to remove a movie and have it remember which colleciton it was in, unless maybe I could export that data to the metadata files once I have everything set up? Anyway, this seems to be my biggest re-occuring headache on Emby, and while my odd hard drive issue (im thinking something to do with my Sine-Wave UPS, not sure) definately makes the problem worse, we would still have the issue if we lost access to media during a RAID rebuild or something. It would be nice to have a fix.
Luke 42246 Posted August 13, 2020 Posted August 13, 2020 Hi there, can you please attach the emby server log from when the movies were removed from the library? thanks.
andrew0404 13 Posted August 13, 2020 Author Posted August 13, 2020 Luke, Attached are the server logs from when the drive went offline and items were removed, and the log after the reboot when the drive was back online. Thanks, embyserver-reboot-drive-online.txt embyserver-drivecrash.txt
