TCEmby1 8 Posted August 12, 2020 Posted August 12, 2020 (edited) I did this 90 days ago and forgot how I got it to work.. I'm using openssl to convert my cert to pfx and it does, just fine: (openssl pkcs12 -export -out certificate.pfx -inkey private.key -in certificate.crt) But it's not working for some reason. The last time I did this I can tell it generated a new 'private.key' file along with the pfx. This time with the above command it's only generating the .pfx file. Is this the issue? What can I do different? Got it fixed--I used the Namecheap converter instead of openssl and it worked! https://decoder.link/converter Edited August 12, 2020 by TCEmby1 2
