somy 25 Posted August 12, 2020 Posted August 12, 2020 Hi, I'd like to report a minor issue with display settings for the user. I use the settings to change the default skin and enable backdrops. Looks to me that when I login from a different device the setting is reset to default. Is the setting stored locally? Or could it be reset when a user login from another device?
Luke 42210 Posted August 12, 2020 Posted August 12, 2020 Hi, these two are per-app settings because you may want them to be different on different devices. 1
somy 25 Posted August 12, 2020 Author Posted August 12, 2020 Just now, Luke said: Hi, these two are per-app settings because you may want them to be different on different devices. 1 minute ago, Luke said: Hi, these two are per-app settings because you may want them to be different on different devices. Hi Luke, that explains - thanks
