roshanconnor 0 Posted August 7, 2020 Posted August 7, 2020 Hello there I have a lot many Files in My media Folder arranged this way Deadpool 2016 Deadpool 2016 720p x264.mkv Deadpool 2016 720p x265.mkv Deadpool 2016 1080p x264.mkv The Avengers 2011 The Avengers 2011 720p x264.mkv The Avengers 2011 1080p x264.mkv Thor 2011 Thor 2011 720p x265.mkv Thor 2011 1080p x26.mkv When I added them to my Library,they are shown as different Movies Like its shown in the Image My request is: Is there way to fix this? Like is there any way for me to show these 3 same movies of different resolution appear inside a single Movie Folder In a way that I can choose the one I wish to Thanks
Carlo 4561 Posted August 7, 2020 Posted August 7, 2020 https://support.emby.media/support/solutions/articles/44001159102-movie-naming
samuelqwe 317 Posted August 7, 2020 Posted August 7, 2020 You need to name your movies according to the Emby naming conventions linked below: Emby Movie Naming From the folder structure you’ve shown though, all you would need is to add a dash in the filename of the movies, after the year. Example: Deadpool 2016 - 720p x264.mkv
Carlo 4561 Posted August 7, 2020 Posted August 7, 2020 I would name your files like the naming convention so your year is in () so it's taken as the year vs part of the movie name. That should fix what looks like and identification issue in the above pic as well.
roshanconnor 0 Posted August 8, 2020 Author Posted August 8, 2020 Thank you very much for all the answers Is there any way that I can rename all of my files this way in Bulk? 12 hours ago, cayars said: https://support.emby.media/support/solutions/articles/44001159102-movie-naming 12 hours ago, cayars said: I would name your files like the naming convention so your year is in () so it's taken as the year vs part of the movie name. That should fix what looks like and identification issue in the above pic as well. 12 hours ago, samuelqwe said: You need to name your movies according to the Emby naming conventions linked below: Emby Movie Naming From the folder structure you’ve shown though, all you would need is to add a dash in the filename of the movies, after the year. Example: Deadpool 2016 - 720p x264.mkv
pwhodges 2023 Posted August 8, 2020 Posted August 8, 2020 13 minutes ago, roshanconnor said: Is there any way that I can rename all of my files this way in Bulk? I use https://www.bulkrenameutility.co.uk/ . However, it doesn't recurse through multiple directories; you'd probably need to use a command line command with regular expressions for that. But as your file names are missing punctuation it would, I think be hard to write a regular expression that would work well over all your files. I hear good things about https://www.filebot.net/ which is often recommended, but I've not tried it myself. Paul
xlerate 9 Posted June 12, 2022 Posted June 12, 2022 I am following the naming convention guide for multiple versions of video in same file and still noticing that they display as duplicates movies within Emby. Interesting is that the same naming convention for TV shows displays as intended where there shows a dropdown to be able to select versions. The Northman (2022)\The.Northman (2022) - 4KHDR The Northman (2022)\The.Northman (2022) - 1080p
GrimReaper 4840 Posted June 12, 2022 Posted June 12, 2022 (edited) 4 minutes ago, xlerate said: The Northman (2022)\The.Northman (2022) - 4KHDR The Northman (2022)\The.Northman (2022) - 1080p If your files are named exactly like that, they're not named properly (you've got one extra dot, so it's treated like multi-movie folder), they need to be named exactly as movie folder is. https://support.emby.media/support/solutions/articles/44001159102-movie-naming Rename, rescan. Edited June 12, 2022 by GrimReaper Append 3 1
xlerate 9 Posted June 13, 2022 Posted June 13, 2022 8 hours ago, GrimReaper said: If your files are named exactly like that, they're not named properly (you've got one extra dot, so it's treated like multi-movie folder), they need to be named exactly as movie folder is. https://support.emby.media/support/solutions/articles/44001159102-movie-naming Rename, rescan. That was it! Thank you. Even see an icon now that apparently indicates more than one file is in there. I use the Emby auto organize plugin that adds the dot in the file names, didnt realize this was the issue. 2 1
JaymzA 2 Posted June 9, 2025 Posted June 9, 2025 (edited) Sorry for resurrecting an old thread, but I wanted to thank @GrimReaper. I was beating my head against the wall trying to figure out why I was getting multiple metadata entries: Until I read this tid-bit "they need to be named exactly as movie folder is." Movie folder was structured as: \M\Matrix, The (1999)\The Matrix (1999) - 1080p.mkv \M\Matrix, The (1999)\The Matrix (1999) - 4K.mkv Now, it is structured as: \M\Matrix, The (1999)\Matrix, The (1999) - 1080p.mkv \M\Matrix, The (1999)\Matrix, The (1999) - 4K.mkv My library is very happy now. I may have to rescan for others with "The". Again, thank you very much GrimReaper!! Edited June 9, 2025 by JaymzA 2
tedfroop21 89 Posted June 9, 2025 Posted June 9, 2025 So many answers are already in the Knowledgbase articles.... https://emby.media/support/articles/Movie-Naming.html#multi-version-movies 2 1
