kodiarnhem 0 Posted August 7, 2020 Posted August 7, 2020 (edited) UPDATE: Problem solved. I am new with Emby. I forgot to save the list   Goodmorning, I've made an m3u list with 30 channels, all 24/7 channels so no proper guide available for channels like that. When I restart the server and start EMBY on my iPad, I still can see all the channels of a previous m3u-file. The other problem is that the synchronization of my EPG remailns at 100% but doesn't close. Could someone help me please?  With kind regards, Kodi Edited August 12, 2020 by kodiarnhem
Carlo 4561 Posted August 7, 2020 Posted August 7, 2020 You will see the old IPTV channels still listed until the new fresh completes. When it's sitting at or close to 100% is doing this last jobs like cleaning out the old EPG and channel info that are no longer needed. So just let it finish the refresh on it's own.
Luke 42237 Posted August 7, 2020 Posted August 7, 2020 Hi, have you run the refresh guide data scheduled task? This happens automatically when you make these kinds of changes, but if you restarted the server you may have interrupted it. Please see if that helps. Thanks.
