fraenhawk 61 Posted July 18, 2014 Posted July 18, 2014 According to Media Info in Windows, the mkvs I'm playing (Attack on Titan) have audio #1 192kbps Japanese, audio #2 448 kbps English. I have my default language set to English. In the web interface for that episode, if I click the Media Info tab, it says Audio Language Eng, Bitrate 448 kbps, so it seems to be filtering to show me the english (and it has the bitrate that matches the correct track). However, when I playback the file in the web client, it plays the japanese track. When I click the audio tracks button it only shows Eng.ac3.448 kbps so it's not like there's another track I can pick. This is on server 3.0.5309.26857. Also, subtitles aren't playing, and I'm wondering if that's because the client thinks it's playing an English track so supressing subs. If I'm reading the transcode logs correctly, it says it's playing 0:1 which is the japanese track even though the display says it's playing the english. 2014-07-17 19:47:01.6696 Info - App: C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140612\ffmpeg.exe -ss 00:01:57.139 -fflags +genpts -i file:"\\WHSHAWK\Shows\Attack on Titan\Season 1\Attack on Titan - S01E03 - A Dull Light in Despair.mkv" -map 0:0 -map 0:1 -map -0:s -vcodec libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -speed 16 -quality good -profile:v 2 -slices 8 -crf 12 -maxrate:v 872001 -bufsize:v (872001*2) -b:v 872001 -r 23.97602 -vsync vfr -map_metadata -1 -threads 2 -acodec libvorbis -ac 2 -ab 128000 -af "aresample=async=1,volume=1" -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\85fdea29f80284c19d74eaccafbd727a.webm" C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\ffmpeg\20140612\ffmpeg.exe -ss 00:02:28.784 -fflags +genpts -i file:"\\WHSHAWK\Shows\Attack on Titan\Season 1\Attack on Titan - S01E03 - A Dull Light in Despair.mkv" -map 0:0 -map 0:1 -map -0:s -vcodec libvpx -force_key_frames expr:gte(t,n_forced*5) -vf "scale=min(iw\,1280):trunc(ow/dar/2)*2" -speed 16 -quality good -profile:v 2 -slices 8 -crf 12 -maxrate:v 872001 -bufsize:v (872001*2) -b:v 872001 -r 23.97602 -vsync vfr -map_metadata -1 -threads 2 -acodec libvorbis -ac 2 -ab 128000 -af "aresample=async=1,volume=1" -y "C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\bc2cd3e243fdd4c561b389272c1daaf6.webm" ffmpeg version N-63911-g3a1c895 Copyright (c) 2000-2014 the FFmpeg developers built on Jun 11 2014 22:01:49 with gcc 4.8.2 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-decklink --enable-zlib libavutil 52. 89.100 / 52. 89.100 libavcodec 55. 66.100 / 55. 66.100 libavformat 55. 43.100 / 55. 43.100 libavdevice 55. 13.101 / 55. 13.101 libavfilter 4. 8.100 / 4. 8.100 libswscale 2. 6.100 / 2. 6.100 libswresample 0. 19.100 / 0. 19.100 libpostproc 52. 3.100 / 52. 3.100 Input #0, matroska,webm, from 'file:\\WHSHAWK\Shows\Attack on Titan\Season 1\Attack on Titan - S01E03 - A Dull Light in Despair.mkv': Metadata: encoder : libebml v1.3.0 + libmatroska v1.4.1 creation_time : 2014-06-10 06:19:32 Duration: 00:24:12.06, start: 0.000000, bitrate: 3208 kb/s Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) Metadata: BPS : 2566702 BPS-eng : 2566702 DURATION : 00:24:12.034000000 DURATION-eng : 00:24:12.034000000 NUMBER_OF_FRAMES: 34814 NUMBER_OF_FRAMES-eng: 34814 NUMBER_OF_BYTES : 465867432 NUMBER_OF_BYTES-eng: 465867432 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_DATE_UTC: 2014-06-10 06:19:32 _STATISTICS_WRITING_DATE_UTC-eng: 2014-06-10 06:19:32 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:1(jpn): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: BPS : 192000 BPS-eng : 192000 DURATION : 00:24:12.064000000 DURATION-eng : 00:24:12.064000000 NUMBER_OF_FRAMES: 45377 NUMBER_OF_FRAMES-eng: 45377 NUMBER_OF_BYTES : 34849536 NUMBER_OF_BYTES-eng: 34849536 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_DATE_UTC: 2014-06-10 06:19:32 _STATISTICS_WRITING_DATE_UTC-eng: 2014-06-10 06:19:32 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 448 kb/s Metadata: BPS : 448000 BPS-eng : 448000 DURATION : 00:24:12.064000000 DURATION-eng : 00:24:12.064000000 NUMBER_OF_FRAMES: 45377 NUMBER_OF_FRAMES-eng: 45377 NUMBER_OF_BYTES : 81315584 NUMBER_OF_BYTES-eng: 81315584 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_DATE_UTC: 2014-06-10 06:19:32 _STATISTICS_WRITING_DATE_UTC-eng: 2014-06-10 06:19:32 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:3(eng): Subtitle: subrip (default) (forced) Metadata: title : Full BPS : 71 BPS-eng : 71 DURATION : 00:23:54.266000000 DURATION-eng : 00:23:54.266000000 NUMBER_OF_FRAMES: 351 NUMBER_OF_FRAMES-eng: 351 NUMBER_OF_BYTES : 12756 NUMBER_OF_BYTES-eng: 12756 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_DATE_UTC: 2014-06-10 06:19:32 _STATISTICS_WRITING_DATE_UTC-eng: 2014-06-10 06:19:32 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Stream #0:4(eng): Subtitle: subrip Metadata: title : Forced BPS : 6 BPS-eng : 6 DURATION : 00:23:35.456000000 DURATION-eng : 00:23:35.456000000 NUMBER_OF_FRAMES: 22 NUMBER_OF_FRAMES-eng: 22 NUMBER_OF_BYTES : 1142 NUMBER_OF_BYTES-eng: 1142 _STATISTICS_WRITING_APP: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_APP-eng: mkvmerge v7.0.0 ('Where We Going') 64bit built on Jun 9 2014 15:16:27 _STATISTICS_WRITING_DATE_UTC: 2014-06-10 06:19:32 _STATISTICS_WRITING_DATE_UTC-eng: 2014-06-10 06:19:32 _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES [libvpx @ 04bc0440] v1.3.0 Output #0, webm, to 'C:\Users\Administrator\AppData\Roaming\MediaBrowser-Server\transcoding-temp\bc2cd3e243fdd4c561b389272c1daaf6.webm': Metadata: encoder : Lavf55.43.100 Stream #0:0: Video: vp8 (libvpx), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 872 kb/s, 23.98 fps, 1k tbn, 23.98 tbc (default) Metadata: encoder : Lavc55.66.100 libvpx Stream #0:1: Audio: vorbis (libvorbis), 48000 Hz, stereo, fltp, 128 kb/s (default) Metadata: encoder : Lavc55.66.100 libvorbis Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> vp8 (libvpx)) Stream #0:1 -> #0:1 (ac3 (native) -> vorbis (libvorbis)) P.S. Loving getting to the logs from the web interface now!
Luke 42287 Posted July 18, 2014 Posted July 18, 2014 it appears the jp track is marked as default so check your profile preferences
fraenhawk 61 Posted July 18, 2014 Author Posted July 18, 2014 What am I looking for? The "Play default audio track regardless of language" checkbox? It's unchecked. Even if that was on, would it cause the list of audio tracks to show a checkmark next to the english track even though that's not what's playing?
audigy 1 Posted July 18, 2014 Posted July 18, 2014 is there an option to disable tv theme playback in the web client?
fraenhawk 61 Posted July 26, 2014 Author Posted July 26, 2014 it appears the jp track is marked as default so check your profile preferences @@Luke is there any other info I can send you that might help? I answered your question above.
fraenhawk 61 Posted July 26, 2014 Author Posted July 26, 2014 Well, this got me to learn how to use mkvpropedit. I toggled off forced for audio 1 and subtitle 1, and turned on forced for subtitle 2 (the forced). Now everything (both LAV for MBC and the web client) are happy. Interesting to note though, and maybe this will give you a clue of something that might have happened during the part of the database scan that checks the media info: With the original file that I posted the logs for, on the media info tab of the web client, it just showed the Eng 448 (as I posted in original post above). I made my change and rescanned the libaray and now the media info tab shows the info for ALL the tracks. Both Japanese and English. And when I play it back, not only is the correct set playing (english with the forced subs only, not full), but all of the others are now choices in the player. Before I had no other choices - I couldn't switch between English and Japanese. Makes me wonder if all this had to do with a failed mediainfo read. I kept one of the original, unaltered files in case you want me to run any other tests. 1
fraenhawk 61 Posted July 26, 2014 Author Posted July 26, 2014 Ok, this is really bizarre (and related to this same audio language issue) but I don't think it's necessarily an MBC problem. I thought I'd start here though to see if anyone has an idea before I try some general Media Center boards. Those same files that are now set with the JPN audio default, but none forced. They play great in the web client now (english by default since that's my default lang). If I go to an MBC machine, sometimes they're in English, sometimes Japanese. I figured out how to make it happen one way or another, and I noticed this because I had the mouse out (rare on my HTPC) and WMC wasn't maximized to I could see what was going on with LAV. If I start WMC from the desktop with the mouse, the state is remembered (i.e. if it was restored it starts restored, if it was maximized it starts maximized) and the audio will ALWAYS be English. If I browse to the file in Explorer and tell it to play in Media Center, it remembers its state and plays in English. If I press the big Green button on the remote, it always starts WMC maximized and the audio always plays the Japanese track!! It's almost like starting with the button makes the system start in some kind of safe mode and there's no default language set. WTF?! Anyone run across this before?
