Guest Posted August 5, 2020 Posted August 5, 2020 Is there anyway to adjust brightness in video player? I find HDR content to be quite dim and requires me to turn my phone's brightness way up.
Luke 42244 Posted August 5, 2020 Posted August 5, 2020 Hi, this is something we used to have and plan to restore in future updates. Thanks for the feedback. 1
Carlo 4561 Posted August 5, 2020 Posted August 5, 2020 (edited) 4 hours ago, Figment123456 said: Is there anyway to adjust brightness in video player? I find HDR content to be quite dim and requires me to turn my phone's brightness way up. Out of curiosity is your phone HDR compatible or is SDR? They use two different color spaces and HDR content played on SDR will look bad by default. Edited August 5, 2020 by cayars
Guest Posted August 6, 2020 Posted August 6, 2020 HDR. Is a Pixel 4XL. Honestly it's only with my rip of Revenge of the Sith it's bad. Like very dim and a yellowish tint.
Carlo 4561 Posted August 6, 2020 Posted August 6, 2020 Can you post the metadata for that file? Just go to the detail screen of that movie and scroll the the bottom as an admin.
Carlo 4561 Posted August 6, 2020 Posted August 6, 2020 Yep, that's it. What the color transfer on you other HDR that does look correct?
Guest Posted August 6, 2020 Posted August 6, 2020 It's the same. It looks fine now..maybe it was just my phone.
