MartijnB 0 Posted August 5, 2020 Posted August 5, 2020 Good evening, I am fairly new to emby (jumped from Plex). I have my server running on ubuntu. I am trying to stream to a fetchtv box (see https://www.fetchtv.com.au/packages/mighty). It seems that libraries containing movies work fine, but those containing tv shows fail. I browse to the TV Shows library, "Continue watching" or "Latest" folders work, but clicking on "shows" or "folders" does nothing. This happens in multiple libraries, each is of the type "tv shows", but those listed as "movies" are fine. The entire network is gigabit, i can't think of what this could be... any ideas?
Luke 42237 Posted August 5, 2020 Posted August 5, 2020 Hi there, can you please attach the emby server log? Thanks.
MartijnB 0 Posted August 5, 2020 Author Posted August 5, 2020 (edited) oops... server log attached. Few additional notes: If i add the same content using the library type "Mixed content" it works fine. Seems to be something about the TV Shows type. Also turned off the real time monitoring of libraries as this caused some error. embyserver (2).txt Edited August 5, 2020 by MartijnB additional info
Luke 42237 Posted August 8, 2020 Posted August 8, 2020 Does the fetchtv box support the content that you're trying to play?
MartijnB 0 Posted August 8, 2020 Author Posted August 8, 2020 (edited) Yes, it does. Edited August 8, 2020 by MartijnB Add visual
MartijnB 0 Posted August 8, 2020 Author Posted August 8, 2020 avi, mkv, mov, mpeg, mpg, mp4. The system will play it if i go through the mediahub > NAS > folder > select file > play It fails (as per video) if i go through emby (DNLA) > folder > And this only for type tv shows.
MartijnB 0 Posted August 9, 2020 Author Posted August 9, 2020 Can you confirm that browsing the DNLA server isn't captured in the log... only playing files? I have enabled DNLA logging for now, I see the following: 2020-08-09 09:52:57.492 Info HttpServer: HTTP GET http://192.168.0.200:8096/videos/143402/stream.mkv?DeviceId=d717044bf032b1a33f6618be0256002c&MediaSourceId=06487825ce3bb0ba1f197a6fd78015f7&Static=true&PlaySessionId=3b7f0ae7fc6d8528bcaa4913ac6ba451. HOST=192.168.0.200:8096, Range=bytes=13926400-295906147, DATE=Sat, 08 Aug 2020 23:52:57 GMT, CONNECTION=close, USER-AGENT=Linux/3.14.28-1.6, HTTP/1.0, Portable SDK for HTTP devices 2020-08-09 09:52:57.492 Info HttpServer: SocketException: http://192.168.0.200:8096/videos/143402/stream.mkv?DeviceId=d717044bf032b1a33f6618be0256002c&MediaSourceId=06487825ce3bb0ba1f197a6fd78015f7&Static=true&PlaySessionId=3b7f0ae7fc6d8528bcaa4913ac6ba451 2020-08-09 09:52:57.492 Info HttpServer: HTTP Response 206 to 192.168.0.136. Time: 96ms. http://192.168.0.200:8096/videos/143402/stream.mkv?DeviceId=d717044bf032b1a33f6618be0256002c&MediaSourceId=06487825ce3bb0ba1f197a6fd78015f7&Static=true&PlaySessionId=3b7f0ae7fc6d8528bcaa4913ac6ba451 2020-08-09 09:52:58.152 Info HttpServer: SocketException: http://192.168.0.200:8096/videos/143402/stream.mkv?DeviceId=d717044bf032b1a33f6618be0256002c&MediaSourceId=06487825ce3bb0ba1f197a6fd78015f7&Static=true&PlaySessionId=3b7f0ae7fc6d8528bcaa4913ac6ba451 2020-08-09 09:52:58.152 Info HttpServer: HTTP Response 206 to 192.168.0.136. Time: 661ms. http://192.168.0.200:8096/videos/143402/stream.mkv?DeviceId=d717044bf032b1a33f6618be0256002c&MediaSourceId=06487825ce3bb0ba1f197a6fd78015f7&Static=true&PlaySessionId=3b7f0ae7fc6d8528bcaa4913ac6ba451 2020-08-09 09:54:32.544 Info HttpServer: HTTP GET http://192.168.0.200:8096/emby/System/Logs/embyserver.txt/Lines?SortBy=IsFolder%2CSortName&SortOrder=Ascending&Fields=BasicSyncInfo%2CProductionYear%2CStatus%2CEndDate&ImageTypeLimit=1&EnableImageTypes=Primary%2CBackdrop%2CThumb&StartIndex=600&Limit=100&EnableTotalRecordCount=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/83.0.4103.61 Safari/537.36 I stopped playing a file (loaded through "Latest") at 2020-08-09 09:52:58.152 and then waited until my clock turned to 9:54AM and browsed through the emby server (via DNLA) but nothing is showing in the log.
Luke 42237 Posted August 9, 2020 Posted August 9, 2020 Did you also enable debug logging in the server logs section?
MartijnB 0 Posted August 9, 2020 Author Posted August 9, 2020 Done. What i see in the logs now (added the FetchTV profile in DLNA): 2020-08-10 05:10:34.944 Debug HttpServer: HTTP POST http://192.168.0.200:8096/dlna/41e72e403fba4a338e42b3b65f8925df/contentdirectory/control. UserAgent: Linux/4.1.20-1.9, UPnP/1.0, DLNADOC/1.50 2020-08-10 05:10:34.944 Debug Dlna: Found matching device profile: FetchTV 2020-08-10 05:10:34.945 Debug Dlna: Received control request Browse 2020-08-10 05:10:34.974 Debug HttpServer: HTTP Response 200 to 192.168.0.104. Time: 30ms. http://192.168.0.200:8096/dlna/41e72e403fba4a338e42b3b65f8925df/contentdirectory/control If i put " http://192.168.0.200:8096/dlna/41e72e403fba4a338e42b3b65f8925df/contentdirectory/control" in a webbrowser, i get: Unable to find the specified file.
Luke 42237 Posted August 9, 2020 Posted August 9, 2020 Right you can't put that in a browser, that won't work. So you created a device profile, why?
MartijnB 0 Posted August 9, 2020 Author Posted August 9, 2020 Cause I am grasping at straws here. Trying to identify why FetchTV isn't reading the folders of the tv shows library type. If you want to know, I also started looking through the code in Emby.Dlna.dll, seeing if anything there could point me in the right direction. Unless i get this working, I won't be looking at Premiere. Maybe I need to go back to plex.
Luke 42237 Posted August 9, 2020 Posted August 9, 2020 Most likely the issue is that fetchtv doesn't like something about our xml response. I'm just not sure what it is yet.
GaryYoung 0 Posted January 22, 2021 Posted January 22, 2021 Hi MartijnB, Same problem here - I have 5 Fetch boxes on two accounts and I can get it work perfectly when going direct to another DLNA server. Installed emby (and works great using Android App on same TV) - Fetch shows folders, but does not let me access them I will update here if I find any settings / solutions to try. We need some AU support.....
Luke 42237 Posted January 22, 2021 Posted January 22, 2021 1 hour ago, GaryYoung said: Hi MartijnB, Same problem here - I have 5 Fetch boxes on two accounts and I can get it work perfectly when going direct to another DLNA server. Installed emby (and works great using Android App on same TV) - Fetch shows folders, but does not let me access them I will update here if I find any settings / solutions to try. We need some AU support..... Hi, what happens when you try?
MartijnB 0 Posted January 22, 2021 Author Posted January 22, 2021 3 hours ago, GaryYoung said: Hi MartijnB, Same problem here - I have 5 Fetch boxes on two accounts and I can get it work perfectly when going direct to another DLNA server. Installed emby (and works great using Android App on same TV) - Fetch shows folders, but does not let me access them I will update here if I find any settings / solutions to try. We need some AU support..... I have given up, I'm PlexPass user now.
Luke 42237 Posted February 13, 2021 Posted February 13, 2021 Hi, would you mind trying Emby Server 4.6+ (as of today in beta), combined with the 1.0.45 Dlna plugin update(or greater)? Please let us know if this helps. Thanks !
GaryYoung 0 Posted January 3, 2022 Posted January 3, 2022 I came back to try this after migrating Emby to a new server. Emby 4.6.7.0 and DLNA 1.0.69.0. Similar problems to what has been reported. Fetch shows the content, but only the "All Files" folders actually allow access. Selecting "Folders" or "Genres" or other options, just flash a quick "Continue Watching" message but no access. Setup for Movies, TV Shows, Music and Music Videos. Only Music Videos display as actual folders (and no other options). Cannot search in the "All files" view. As noted - Emby app on Android TV works fine. Turned on DLNA logging, but not log file is created in the Logs folder ?
Luke 42237 Posted January 4, 2022 Posted January 4, 2022 2 hours ago, GaryYoung said: Turned on DLNA logging, but not log file is created in the Logs folder ? It gets added to the main emby server log.
GaryYoung 0 Posted January 4, 2022 Posted January 4, 2022 OK - I will turn it back on, and let it run for a day or so. I will then try and extract any dlna related lines.
GaryYoung 0 Posted January 5, 2022 Posted January 5, 2022 Not a lot showing up. Access DLNA via the Sony Bravia TV works as expected. Access via the fetch box does not seem to ever flag a record in the log (except maybe the last few lines ? ) Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:52.269 Info Server: http/1.1 HEAD http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:52.277 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, Range=bytes=0-, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:52.444 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, Range=bytes=440786851-, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:52.590 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, Range=bytes=1435837763-, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:52.747 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, Range=bytes=3909820923-, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:52.914 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, Range=bytes=4-, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:29:53.032 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/125912/stream.mkv?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=d6deca595f0f4c15ea092df749de0637&Static=true&PlaySessionId=edc6384452977a78025f3d963e91e561. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:30:08.141 Info Server: http/1.1 HEAD http://192.168.5.2:8096/videos/215801/stream.mp4?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=9cd9559fe6f747f0da705c7ce9fd09c1&Static=true&PlaySessionId=18a7eb4fe81d6f57ec96af766f34d872. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:30:08.152 Info Server: http/1.1 HEAD http://192.168.5.2:8096/videos/215801/stream.mp4?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=9cd9559fe6f747f0da705c7ce9fd09c1&Static=true&PlaySessionId=18a7eb4fe81d6f57ec96af766f34d872. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 10:30:08.159 Info Server: http/1.1 GET http://192.168.5.2:8096/videos/215801/stream.mp4?DeviceId=fb559608b7cbf3b71dc91af9706ac0ed&MediaSourceId=9cd9559fe6f747f0da705c7ce9fd09c1&Static=true&PlaySessionId=18a7eb4fe81d6f57ec96af766f34d872. Connection=Keep-Alive, Pragma=getIfoFileURI.dlna.org, Accept-Encoding=gzip, Host=192.168.5.2:8096, Range=bytes=0-, User-Agent=Dalvik/2.1.0 (Linux; U; Android 9; BRAVIA 4K UR3 Build/PTT1.190515.001.S104), transferMode.dlna.org=Streaming, getcontentFeatures.dlna.org=1 embyserver-63776937600.txt:2022-01-04 13:44:34.009 Info Server: http/1.1 GET http://192.168.5.2:8096/emby/System/Configuration/dlna?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox&X-Emby-Device-Id=9ef95a9a-5ba8-4286-a475-f14c83f75322&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:95.0) Gecko/20100101 Firefox/95.0 embyserver-63776937600.txt:2022-01-04 13:44:34.010 Info Server: http/1.1 Response 200 to 192.168.5.50. Time: 1ms. http://192.168.5.2:8096/emby/System/Configuration/dlna?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox&X-Emby-Device-Id=9ef95a9a-5ba8-4286-a475-f14c83f75322&X-Emby-Client-Version=4.6.7.0 embyserver-63776937600.txt:2022-01-04 13:44:34.026 Info Server: http/1.1 POST http://192.168.5.2:8096/emby/System/Configuration/dlna?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox&X-Emby-Device-Id=9ef95a9a-5ba8-4286-a475-f14c83f75322&X-Emby-Client-Version=4.6.7.0. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:95.0) Gecko/20100101 Firefox/95.0 embyserver-63776937600.txt:2022-01-04 13:44:34.088 Info Server: http/1.1 Response 204 to 192.168.5.50. Time: 62ms. http://192.168.5.2:8096/emby/System/Configuration/dlna?X-Emby-Client=Emby Web&X-Emby-Device-Name=Firefox&X-Emby-Device-Id=9ef95a9a-5ba8-4286-a475-f14c83f75322&X-Emby-Client-Version=4.6.7.0 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAAC_L2_ADTS_320;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_320;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_192;DLNA.ORG_FLAGS=9D300000000000000000000000000000 embyserver-63776937600.txt:http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=HEAACv2_L2_128;DLNA.ORG_FLAGS=9D300000000000000000000000000000 [root@cinderella logs]#
