Luke 42241 Posted July 19, 2022 Posted July 19, 2022 Yes it might be possible to support directly in future updates. Thanks. 3
Carlo 4561 Posted July 19, 2022 Posted July 19, 2022 I tried to create an account via VPN so I could setup and try this. That way I'm at least familiar with it. It doesn't like my email accounts and "knows" I'm across the pond due to my email addresses. If anyone has a spare free account or could create one I'd greatly appreciate if you could PM me the account info. Appreciated, Carlo
pünktchen 1411 Posted July 19, 2022 Posted July 19, 2022 @cayarsin Telerising there's an option to get a Zattoo lineup without an account. That gives you only a handful channels, but it's enough for testing. 1 1
pünktchen 1411 Posted July 19, 2022 Posted July 19, 2022 Oh, and you have to enable the advanced option to append m3u8 to the playlist streams to get it working for Emby. 1 1
horstepipe 423 Posted September 4, 2022 Posted September 4, 2022 On 7/19/2022 at 9:23 AM, pünktchen said: @popy if you setup DVBViewer between Telerising and Emby you can reduce channel switching times by 1 to 3 seconds dependent on the Emby client. do you know whether I'd also have that benefit with tvheadend? dvbviewer doesn't seem to be available for Linux.
pünktchen 1411 Posted September 4, 2022 Posted September 4, 2022 Doesn't Tvheadend need pipe through ffmpeg? If so, then it's probably even slower than directly in Emby. 1
horstepipe 423 Posted September 5, 2022 Posted September 5, 2022 14 hours ago, pünktchen said: Doesn't Tvheadend need pipe through ffmpeg? If so, then it's probably even slower than directly in Emby. I think so, yes. Are you aware of any other alternative for Linux (ubuntu headless) ?
pünktchen 1411 Posted September 5, 2022 Posted September 5, 2022 NextPVR and TVMosaic CE. But i don't know if they support fmp4 streams. 1
horstepipe 423 Posted September 5, 2022 Posted September 5, 2022 4 minutes ago, pünktchen said: NextPVR and TVMosaic CE. But i don't know if they support fmp4 streams. thank you. Maybe somebody using one of these can report how good they work (in combination with Emby and/or the telerising api).
horstepipe 423 Posted September 21, 2022 Posted September 21, 2022 I ended up using xteve in between (with ffmpeg buffer). Emby is direct playing the streams now and I can disable remux for all users. Best regards
popy 73 Posted September 21, 2022 Posted September 21, 2022 8 minutes ago, horstepipe said: I ended up using xteve in between (with ffmpeg buffer). Emby is direct playing the streams now and I can disable remux for all users. Best regards so just to got you right? You are using telerising api to get the m3u, fedding that into xteve which generates m3u for emby? Correct? How re the switching times between channels? That's the only downside using telerising -> emby directly. thx
horstepipe 423 Posted September 21, 2022 Posted September 21, 2022 You add xteve as hdhr tuner, not by m3u - but besides of this, correct. I don’t think switching times will differ as xteve needs to use ffmpeg, too. But I will check with a stop watch again.
popy 73 Posted September 21, 2022 Posted September 21, 2022 ok, thx. so what's the benefit of adding another ffmpeg (xteve) in the chain? my guess is, it makes it even slower? Would be nice if you can check the switching times.
horstepipe 423 Posted September 21, 2022 Posted September 21, 2022 Benefit is that I do not have to enable remux for my users. This sometimes makes the server unnecessarily remux videos. in fact it seems to be a little better with xteve: xteve -> emby -> client: 7 seconds emby -> client: 10 seconds.
popy 73 Posted September 21, 2022 Posted September 21, 2022 ok thx. than it's no option. @cayarsdid you get an test account running with an VPN? Would be really nice if native support (via plugin) of zattoo will come. thx
Carlo 4561 Posted September 22, 2022 Posted September 22, 2022 No, even with the VPN running through a server in Switzerland it goves me an error just like without it. I'm pretty sure they are filtering out known VPN IP address spaces. If anyone knows a VPN that works I might be able to get a test/trial and test with that.
popy 73 Posted September 25, 2022 Posted September 25, 2022 I am using SmartDNSProxy myself from Austria and can use the Switzerland channels. You must set your device DNS to the ones given from SDNS proxy.
palight 0 Posted December 9, 2022 Posted December 9, 2022 On 9/21/2022 at 8:14 AM, horstepipe said: Benefit is that I do not have to enable remux for my users. This sometimes makes the server unnecessarily remux videos. in fact it seems to be a little better with xteve: xteve -> emby -> client: 7 seconds emby -> client: 10 seconds. Hi, I can't made telerising + xteve work. Can you tell me your settings in both of them ? Thanks a lot.
horstepipe 423 Posted December 11, 2022 Posted December 11, 2022 On 12/9/2022 at 6:15 PM, palight said: Hi, I can't made telerising + xteve work. Can you tell me your settings in both of them ? Thanks a lot. What exactly does not work? Telerising without xteve is fine? So the m3u links work e.g. in vlc?
Meeko 35 Posted April 21, 2024 Posted April 21, 2024 I have integrate zattoo with Telerising-api!! link: https://github.com/sunsettrack4/telerising-api it works perfect. Only the start times are a little bit longer. Epg i have this: https://github.com/sunsettrack4/script.service.easyepg-lite best regards
