Antonio_Ticsa 3 Posted August 4, 2020 Posted August 4, 2020 Tengo un problema con IPTV mas especifico en M3U Sintonizador tengo canales de TV en HD pero al configurar y ver lo en emby la calidad baja a 480pPero si reprodusco la M3U en VLC esta en HD Alguien sabe en que consista este errorGracias
Carlo 4561 Posted August 4, 2020 Posted August 4, 2020 (edited) It appears it's having trouble playing the stream as is so it ends up transcoding and using a lower resolution. Is this a remote playback or local on your lan? Edited August 6, 2020 by cayars
Antonio_Ticsa 3 Posted August 4, 2020 Author Posted August 4, 2020 cayars exacto. Si la reproducción de la IPTV M3U es remota. Y las pruebas que hecho son locales. Ejemplo : 10.10.10.200/24 Un consejo de como puedo reparar este error Gracias
Carlo 4561 Posted August 6, 2020 Posted August 6, 2020 If you look at the M3U file in notepad and search to find the Fox HD channel used above what does it look like? Can you post the link here changing the provider domain to IPTV.com and of course changing your username and password to the literal "username" and "password"? That way that one line only would not give away your username, password or iptv provider. I'd like to look at the format they are using. Alternately you can just PM me that info and not redact it and I could test that specific channel. What I have a feeling they might be doing is providing your multiple streams that could be used. They might have the worst listed first the best stream last. VLC will choose the best stream but Emby will use the first at present. I believe this is being addressed in the new Live TV project. If you PM me a link I can actually use to test with for a couple of minutes I can rule this out or confirm that's the problem and we can take it from there once we know the cause. It could also just be an Emby server or client setting as well but I'm thinking the above. I could also TeamView in to your system to check but I don't speak Spanish so if you don't speak English we would have to use google Translate which is time consuming. I'd like to start if possible just looking at the stream itself. Carlo
Luke 42241 Posted August 6, 2020 Posted August 6, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
eltioares 9 Posted August 11, 2020 Posted August 11, 2020 Hola, estaba interesado a comprar el emby premium, para poner el IPTV, hay algun apartado donde me digan donde puedo conseguir las direcciones y como configurar la IPTV? Un saludo ^^.
vdatanet 1619 Posted August 11, 2020 Posted August 11, 2020 1 hour ago, eltioares said: Hola, estaba interesado a comprar el emby premium, para poner el IPTV, hay algun apartado donde me digan donde puedo conseguir las direcciones y como configurar la IPTV? Un saludo ^^. Las direcciones IPTV debes aportarlas tu, por ejemplo, una playlist m3u. Una vez dispongas de esta playlist, tan solo hace falta configurar un sintonizador m3u indicando esta playlist.
eltioares 9 Posted August 11, 2020 Posted August 11, 2020 Sabes donde puede encontrar direcciones de IPTV ? puede que esten gratis en pelis a la carta e leido algo pero no e encontrado nada. Y lo de M3u es un pluguin que se instala en el emby server? Gracias ^^
vdatanet 1619 Posted August 11, 2020 Posted August 11, 2020 40 minutes ago, eltioares said: Sabes donde puede encontrar direcciones de IPTV ? puede que esten gratis en pelis a la carta e leido algo pero no e encontrado nada. Y lo de M3u es un pluguin que se instala en el emby server? Gracias ^^ El sintonizador m3u está integrado en Emby, no hace falta ningún plugin: https://support.emby.media/support/solutions/articles/44001160415-live-tv-setup Yo tengo contratado Movistar+, que es el único operador de España que permite contratar IPTV sin DRM.
eltioares 9 Posted August 13, 2020 Posted August 13, 2020 Gracias a todos por la respuesta he encontrado esto para aclarar mi ignorancia @ebr @legallink 1
eltioares 9 Posted August 14, 2020 Posted August 14, 2020 (edited) Nada el video que pase antes no funciona. Ahora e visto esta guía a ver que tal pero me e perdido en la parte De vuelta al panel de TV, iremos a Entradas de TV, no se donde esta este apartado. ¿alguien me puede hechar una mano? E comprado emby premium al final y me gustaria poner la iptv. Tengo un pc de sobremesa potente haciendo de servidor me gustaria saber en que me equivoco, o algun tutoria que me sirva uso esta url: https://raw.githubusercontent.com/salondigital/epg/master/guiatv.xml Agredeceria cualquier ayuda. Edited August 14, 2020 by eltioares
vdatanet 1619 Posted August 14, 2020 Posted August 14, 2020 30 minutes ago, eltioares said: Nada el video que pase antes no funciona. Ahora e visto esta guía a ver que tal pero me e perdido en la parte De vuelta al panel de TV, iremos a Entradas de TV, no se donde esta este apartado. ¿alguien me puede hechar una mano? E comprado emby premium al final y me gustaria poner la iptv. Tengo un pc de sobremesa potente haciendo de servidor me gustaria saber en que me equivoco, o algun tutoria que me sirva uso esta url: https://raw.githubusercontent.com/salondigital/epg/master/guiatv.xml Agredeceria cualquier ayuda. ¿Tienes el servidor Emby instalado en tu pc de sobremesa? Deberías empezar por aquí: https://support.emby.media/support/solutions/articles/44001159034-quick-start Después debes configurar la IPTV mediante un M3U tuner, recuerda que tu debes aportar la lista. Emby nunca proporciona contenidos. https://support.emby.media/support/solutions/articles/44001160415-live-tv-setup https://github.com/MediaBrowser/Wiki/wiki/M3U Tuners Finalmente, instala la aplicación Emby en tu televisor LG.
eltioares 9 Posted August 18, 2020 Posted August 18, 2020 Gracias a todos ya esta ya funciona, era culpa mia por no poner una m3u correcta. 2
eltioares 9 Posted August 21, 2020 Posted August 21, 2020 (edited) Retomando el tema este xD, soy un cabezota ^^! La dirección que quiero poner es una que te da una aplicación de móvil llamada Wiseplay la dirección es ***************. W3u ¿se puede poner de alguna manera? que ya con el movil si funciona con la aplicación de iptv pero con el emby no, ¿se puede poner de alguna manera? no se si puedo poner la dirección que me han pasado entera. Edited August 21, 2020 by eltioares
vdatanet 1619 Posted August 21, 2020 Posted August 21, 2020 49 minutes ago, eltioares said: Retomando el tema este xD, soy un cabezota ^^! La dirección que quiero poner es una que te da una aplicación de móvil llamada Wiseplay la dirección es ***************. W3u ¿se puede poner de alguna manera? que ya con el movil si funciona con la aplicación de iptv pero con el emby no, ¿se puede poner de alguna manera? no se si puedo poner la dirección que me han pasado entera. Las listas .w3u son especificas de la aplicación Wiseplay. Emby solo soporta lista m3u. No se si habrá algun conversor w3u a m3u.
eltioares 9 Posted August 21, 2020 Posted August 21, 2020 Y los plugins que hay en la aplicación para iptv no sirven para nada ?
vdatanet 1619 Posted August 21, 2020 Posted August 21, 2020 Hombre, para algo sirven, pero para listas w3u no. Crea un tópico en "Feature requests" solicitando soporte para este tipo de listas. También puedes editar el fichero, extraer las URLs y crear una playlist m3u o usar el plugin IPTV creando un canal para cada URL.
Banquero 38 Posted August 30, 2020 Posted August 30, 2020 Buenas noches, yo tengo contratado Movistar +. Como puedo averiguar mi lista m3u, para ver Movistar, a través de Emby? No se si la pregunta está bien formulada. Muchas gracias...
vdatanet 1619 Posted August 31, 2020 Posted August 31, 2020 (edited) 8 hours ago, Banquero said: Buenas noches, yo tengo contratado Movistar +. Como puedo averiguar mi lista m3u, para ver Movistar, a través de Emby? No se si la pregunta está bien formulada. Muchas gracias... Hola, Movistar no facilita esta información, debes buscar tu por Internet. Tip: haz una búsqueda en google con las palabras movistar vlc, el primer resultado es la información que buscas. Una vez tengas tu playlist, debes instalar un rtp proxy, para convertir los streams udp multicast a streams http unicast, entonces la playlist debe convertirse en: rtp://@239.0.5.185:8208 se convierte en http://ipdelservidorproxy:4022/udp/239.0.0.185:8208 Finalmente, necesitas buscar algún proveedor de datos de guía de programación, ya que Emby no los proporciona para España Ten en cuenta que esto solo funciona en canales sin DRM, los canales con DRM sólo se pueden reproducir con dispositivos de Movistar. Tambien és importante que el servidor esté conectado por ethernet no por wifi. Esta es la única manera de tener television IPTV en Emby en España. Edited August 31, 2020 by vdatanet 1
vdatanet 1619 Posted September 4, 2020 Posted September 4, 2020 On 8/31/2020 at 10:25 AM, vdatanet said: Hola, Movistar no facilita esta información, debes buscar tu por Internet. Tip: haz una búsqueda en google con las palabras movistar vlc, el primer resultado es la información que buscas. Una vez tengas tu playlist, debes instalar un rtp proxy, para convertir los streams udp multicast a streams http unicast, entonces la playlist debe convertirse en: rtp://@239.0.5.185:8208 se convierte en http://ipdelservidorproxy:4022/udp/239.0.0.185:8208 Finalmente, necesitas buscar algún proveedor de datos de guía de programación, ya que Emby no los proporciona para España Ten en cuenta que esto solo funciona en canales sin DRM, los canales con DRM sólo se pueden reproducir con dispositivos de Movistar. Tambien és importante que el servidor esté conectado por ethernet no por wifi. Esta es la única manera de tener television IPTV en Emby en España. @Banquero ¿Has intentado hacer esto? Si necesitas más ayuda ya dirás.
mauricioro 0 Posted November 14, 2020 Posted November 14, 2020 pueden ver varios usuarios una lista m3u?
vdatanet 1619 Posted November 14, 2020 Posted November 14, 2020 1 minute ago, mauricioro said: pueden ver varios usuarios una lista m3u? Depende del proveedor de la lista.
mauricioro 0 Posted November 14, 2020 Posted November 14, 2020 que seria lo que tengo que buscar en una lista oun proveedor de iptv para lograr eso?
