nishwahareesh 2 Posted August 3, 2020 Posted August 3, 2020 well the title explains HOW ITS MEANT TO BE SEEN HOW ITS SEEN THROUGH A BROWSER LOG FILEffmpeg-transcode-2e5de3da-59ec-4e6e-87fe-0c9abef5ea0c_1.txt in the "Processing Plan", in the "SubtitleBurnIn" part it says "false" for burning subtitles but i have this option disabled
nishwahareesh 2 Posted August 3, 2020 Author Posted August 3, 2020 (edited) Quote Hi, are these subtitles external? nope they're muxed into the mkv file Edited August 3, 2020 by nishwahareesh
Luke 42210 Posted August 3, 2020 Posted August 3, 2020 OK, we'd have to go over an example. Please see how to report a media playback issue. Thanks.
pwhodges 2028 Posted August 3, 2020 Posted August 3, 2020 Are you certain the file contains the necessary fonts? Paul
nishwahareesh 2 Posted August 3, 2020 Author Posted August 3, 2020 (edited) 5 hours ago, pwhodges said: Are you certain the file contains the necessary fonts? Paul yes the files do contain the necessary fonts needed for the subtitle it plays perfectly when direct played (android) but when transcoded it does not burn in the fonts (browser) heres a sample of the video Edited August 4, 2020 by nishwahareesh
nishwahareesh 2 Posted August 4, 2020 Author Posted August 4, 2020 Update The subtitles ARE burnt in but the embedded fonts are not included it just burns the text but not the fonts
Luke 42210 Posted August 4, 2020 Posted August 4, 2020 Currently when transcoding we don't use the custom fonts embedded within the video. This is something we plan to revisit in the near future and support it. Thanks for reporting.
nishwahareesh 2 Posted August 4, 2020 Author Posted August 4, 2020 35 minutes ago, Luke said: Currently when transcoding we don't use the custom fonts embedded within the video. This is something we plan to revisit in the near future and support it. Thanks for reporting. Oh alright then hopefully you guys implement it in the next update
nishwahareesh 2 Posted August 4, 2020 Author Posted August 4, 2020 quick question Do I have to worry about my server being unsecured?
Carlo 4561 Posted August 4, 2020 Posted August 4, 2020 Just as much or little as any other website. So if it's just you and your family you can make sure each person uses a unique password just for Emby. Now if someone was to intercept your unencrypted traffic the best they would have is a username/password that works only for your Emby system but not your gmail, bank accounts or any other service. The real need is to protect the user from dumb things like using the same username and password on many different services. A breach on any site would give an attacker access to other services like gmail where a host of information is available as well as resetting passwords on other sites since most sites send an email confirmation or quick update link. So in all honesty if you are just setting up family accounts and make sure the password is unique then the worst compromise is your video collection not the rest of your online data. Hope that helps, Carlo
nishwahareesh 2 Posted August 4, 2020 Author Posted August 4, 2020 37 minutes ago, cayars said: Just as much or little as any other website. So if it's just you and your family you can make sure each person uses a unique password just for Emby. Now if someone was to intercept your unencrypted traffic the best they would have is a username/password that works only for your Emby system but not your gmail, bank accounts or any other service. The real need is to protect the user from dumb things like using the same username and password on many different services. A breach on any site would give an attacker access to other services like gmail where a host of information is available as well as resetting passwords on other sites since most sites send an email confirmation or quick update link. So in all honesty if you are just setting up family accounts and make sure the password is unique then the worst compromise is your video collection not the rest of your online data. Hope that helps, Carlo ahh thanks for the response if thats the case then i might as well use a generated password
Carlo 4561 Posted August 4, 2020 Posted August 4, 2020 Here I'll generate a few for you: Emby4Nish NishRocksItWithEmby Nish&EmbyIsGreat LOL
Carlo 4561 Posted August 4, 2020 Posted August 4, 2020 It's always a good idea to employ SSL when possible but not the end of the world if you don't use it if prepared. Just make sure the password is not anything used anywhere else and you're on pretty good ground as far as not using encryption. Then of course is just good common sense. Logging in from a friends house or from work over WIFI is one thing while logging in from a public hot spot is another as it could be compromised. So use common sense as well when logging in or using non SSL username/password (not just for Emby).
nishwahareesh 2 Posted August 4, 2020 Author Posted August 4, 2020 2 hours ago, cayars said: Then of course is just good common sense. Logging in from a friends house or from work over WIFI is one thing while logging in from a public hot spot is another as it could be compromised. So use common sense as well when logging in or using non SSL username/password (not just for Emby). so like watching your media through some unsecured wifi despite using a strong password is still unsafe?
pwhodges 2028 Posted August 4, 2020 Posted August 4, 2020 Conceivably. But you have to make your own judgement of the actual risk, and the harm it could do - if you stand in a dark street you might get mugged, but you probably don't spend much time worrying about it every time you go out. Someone stealing a password that enables them to view videos from your server does little harm anyway - I suppose they may take up some bandwidth until they realise your taste is not theirs. And after all, there's no money in it - on the whole they're much more likely to try to get passwords for banks and the like, so that's what you should worry about more. Paul
nishwahareesh 2 Posted August 5, 2020 Author Posted August 5, 2020 (edited) 14 hours ago, pwhodges said: Conceivably. But you have to make your own judgement of the actual risk, and the harm it could do - if you stand in a dark street you might get mugged, but you probably don't spend much time worrying about it every time you go out. Someone stealing a password that enables them to view videos from your server does little harm anyway - I suppose they may take up some bandwidth until they realise your taste is not theirs. And after all, there's no money in it - on the whole they're much more likely to try to get passwords for banks and the like, so that's what you should worry about more. Paul Once again thanks for the answer Man I gotta appreciate how fast y'all respond unlike Plex forums I did a complain about no ASS support for Android in their forums and they straight up ip banned me One of the reasons why I switched from Plex to emby Also saw the amazing features you added to the server and immediately bought the monthly subscription Edited August 5, 2020 by nishwahareesh 1
